Samsung 15" Series 9 NP900X4C with Ivy Bridge CPU
Discussion in 'Samsung' started by John Ratsey, Mar 10, 2012.
  1. Thors.Hammer
    Thors.Hammer Notebook Enthusiast
    hwinfo.com has a great program you can download that will let you look at all sorts of information.
  2. John Ratsey
    SEC0500 according to HWiNFO.
    John
  3. raaaabert
    raaaabert Notebook Guru
    Cheers for the i5 v i7 interpretation, so yeah I think I can live with an i5, that said I'm still going to seek the i7 out. Yep I probably don't need 16GB RAM and I'm guessing it'll be pretty expensive anyway.
    Thanks for the picture of the power pack it looks good, nice and slimline. I hate the thought of a 'premium' notebook only to have a chunky power pack.
  4. raaaabert
    Lucky I live in Switzerland then ;)
    [EDIT - 15" NP900X4? isn't even available in Switzerland according to Samsung.ch]
    I was only going to UK for the keyboard layout.
    Did you get it online or in store? as according to Samsung.it the only version available is i5
  5. Buff.12
    Buff.12 Notebook Enthusiast
    I just got mine, and one of the first things I've noticed about it is that the computer emits a high pitched noise when it's on, regardless of whether the power-pack is on/charging or not.
    A little research reckons it's something to do with CPUs when they go into lower power mode. Does anybody else have this problem?
  6. alexcriss
    alexcriss Notebook Guru
    Online, from Supernotebook.it, and it is indeed the i7 version. Samsung.it seems to be failing very hard both in accuracy and in usability.
    Mine is completely silent when idling. No CPU noise, no whatever. I guess you have something defective.
  7. raaaabert
  8. alexcriss
    It's querty, here is a picture of the Italian layout, so you can judge it for yourself ;)
    https://www.dropbox.com/s/ldr8b665vgvu7gb/P1090094.JPG
  9. John Ratsey
    If it is the CPU whine then does using a high performance power plan stop it? I would note that different people have different sensitivity to high frequency sounds - I might not know if my CPU (actually some nearby capacitors) is whining!
    John
  10. raaaabert
