Sager NP9873 i9 10900k upgrade possible?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by theFalconneer, Nov 4, 2021.
  1. theFalconneer
    theFalconneer Newbie
    I have a Sager NP9873 notebook with 2x GTX 1080 sli and i7 8700k and am wondering if I could upgrade it to i9 10900k, and if so how can I do it.
  2. Tech Junky
    Tech Junky Notebook Deity
    Nope Different socket. Going from an 1151to 1200 socket. 12th gen coming soon will be different yet again @ 1700.
    The best you could hope for would be 9th gen and that's not a big enough boost in performance to take on the cost.
    I've got an 8700K in my "server" and have been scoping out the Alder Lake setup this week as Rocket Lake didn't make sense knowing new DDR / PCI versions were coming doubling the PCI bandwidth and 1.5X on the DDR side. The overall boost going from Coffee to Alder is about 50% from cores to cards.
    AL releases on the laptop side though haven't happened yet but, should be in the next couple of months.
    joluke likes this.
  3. theFalconneer
    Oh okay! Thanks for being so detailed! How about upgrading to a core i9 9900k? Money is no object so is it possible with my bios? You mean PCIe?
  4. electrosoft
    electrosoft Perpetualist Matrixist
    Definitely doable.
    Might need to install Dsanke BIOS depending on what BIOS you're running now.
  5. theFalconneer
    I see. Do you know where to get the dsanke bios and the core i9 9900k? Can you link me to where I can find/buy one?
  6. Tech Junky
  7. theFalconneer
    Whoops I am so dumb. I thought there only was a i9 for dtrs like there was a specific mxm version for gpus. Do you know where to get the dsanke bios for my sager np9873? Any help would be appreciated lol
  8. Tech Junky
    Well, there's the I7 versions 9700K / 9700KF... just change the umber for the other version.
    I don't dsanke so, maybe @electrosoft will have the answer.
  9. electrosoft
    http://forum.notebookreview.com/thr...s-now-supported.825558/page-271#post-11126658
    If you do go this route, make sure to read the flashing guide carefully and prepare for a potential unsuccessful flash which means you'll have to manually flash your system with an SPI programmer to get it up and running.
    Reciever and joluke like this.
  10. theFalconneer
    sorry double post, cant seem to delete the duplicate post; my reply is one the second page lol
