Sager np8952 Max Q vs Aero 15
Discussion in 'What Notebook Should I Buy?' started by childprotectorofthenight, Jul 28, 2017.
  1. childprotectorofthenight
    childprotectorofthenight Notebook Geek
    General Questions
    1) What is your budget? 1,700
    d. Mainstream; 15" - 16" screen
    xotic, Hidevolution, gentech pc anywhere honestly
    a. Like: Gigabyte, Sager
    no, Had a bad experience
    gaming and watching movies, schoolwork
    Both
    Yes, HOTS, COD BO3
    Don't need to see
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, Chrome OS, etc.
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    either
    Build Quality and Design
    yes
    3 days
    4-5years
    Notebook Components
    both have ssd
    no
    OK PEOPLE I NEED HELP DECIDING BETWEEN THE TWO. I think the Aero would be a personal choice because of the battery life, and also can anyone tell me where I could get either with a possible student discount. The Aero comes in at 1,899 before tax and the Sager is about the same. Any reseller I can apply a student discount/ any discount with. I'm looking to spend 1,700 max maybe 1,800 if possible. Thank you all
  2. ThatOldGuy
    ThatOldGuy Notebook Deity
    I think the Areo15 is overall a better laptop. It has a more premium fit and finish (it is Gygabyte's flagship laptop where the Sager/clevo is mid range at best). Both will perform just about he same (GTX 1070 Max-Q is about 5% faster than GTX 1060)
    HIDevolution is a great choice for the purchase. They have some of the best re-seller support and helpfulness.
  3. Charles P. Jefferies
    Charles P. Jefferies TG Lead Moderator Super Moderator
    I don't have experience with the Sager, but I am borrowing an Aero 15 at the moment. It's a very solid machine. The per-key RGB keyboard is fantastic. My only personal complaint is that it gets pretty hot while gaming, but that's an assumption you can make with any thin gaming notebook.
    Charles
  4. don_svetlio
    Anything labelled Max-Q is not worth the money currently. I'd go for the Aero. Better battery life and much better value.
  5. childprotectorofthenight
    Does HIDevolution or Gentech offer a student discount? Thanks
  6. Deevs
    Deevs Notebook Enthusiast
    Hi, wondering why you think Max-Q is not worth the money? Didn't it solve the heat issues on the previous model, while maintaining relatively good performance? I was also on the lookout for a thin and light lappy, so I would generally believe Max-Q is best fit.
  7. don_svetlio
    Performance is horrible and it doesn't fix anything. Look at @D2 Ultima 's opinion piece for NBC - the 1080MQ is as slow as a normal 1070 while costing much more. Max-Q is a rip-off and designed to trick people into spending more for less. A 1070MQ is barely faster than a normal 1060. A 1060MQ should be closer to a 1050 Ti than a 1060.
  8. kmeck518
    kmeck518 Notebook Enthusiast
    HIDevolution offers a discount to NBR forum users (you can message Donald@HIDevolution and he can give you details about it), and Gentech does offer a student discount with promo code "edu".
  9. Blacky
    Blacky Notebook Prophet
    This is the best I could find for your budget and specs: search result.
    If you lower your battery life requirements, I could also recommend the P950HR : https://noteb.com/?model/model.php?conf=6425880191676165410&ex=USD
    You can see and change the search parameters using the "Refine results" button in the upper-left part of the search results page. You can also click on the laptops for more information. (EU/US) stands for Europe/USA only model.
  10. D2 Ultima
    D2 Ultima Livestreaming Master
    The Aero 15 is not a good machine out of the box from what I understand. It needs some liquid metal on it and is extremely expensive for what it provides. I would pick the 1070MQ in the P950HR over it. While the unit is better than a Razer, I think Gigabyte is off their rocker offering such things at the price it comes at. The screen is not good, the heat is rather high at stock, and storage expansion is not that great. If they had sorted it out more from the gate and reduced the price a bit, I'd say it'd be a nice quality machine. But that's pretty much it.
    As far as I can tell, the Aero 15 is more expensive and worse performing, so... I don't know why I would recommend it really.
