Sager NP8454 (Clevo PB51RF-G) early impression
Discussion in 'Sager and Clevo' started by Sabs47, Jul 6, 2019.
  1. xklis
    xklis Notebook Consultant
    @Prema
    Hi !
    I see that reseller 'Dreammachines' is offering 'prema bios' for both clevo based unit pb51rf and pb71rf.
    So maybe you can answer to my questions.
    Actually i've only seen (in the european market) i9-9980hk with PB50RF (so no g-sync) with only 240hz display or with PB71RF-G with 144hz display.
    Do you know if PB50RF(-G), PB51RF(-G) have the same exact motherboard ?
    I mean do NON gsync units still have MUX chips ? If so, can they be re-activated ?
    What i want to ask you is if i buy a PB50RF and than replace stock 240hz display with a certified gsync 144hz panel, will g-sync now work on my new custom PB50RF-G with i9-9980hk ?
  2. Mark J Foster
    Mark J Foster Notebook Geek
    Hi, Meaker! FYI for your Sager team, this system is currently listed as #8 (and #13) on Passmark's Top 20 Fastest Laptops ever page! Even better, if Passmark would accept results within 5% of my previous high score, this notebook would be in 3rd place. As far as I'm concerned, achieving this with a 4K monitor makes this #1!
    Once again, kudos to the team that built such a great product. Well done!
  3. Meaker@Sager
    The desktop chip machines would take #1 too but that's hard for them to detect ;)
  4. Papusan
    Passmark leaderboard is useless. And their software ain’t much better. @Mr. Fox:rolleyes:
    Mr. Fox likes this.
  5. Stooj
    Stooj Notebook Deity
    Wow...I should run passmark on mine and push that number up a bit. Mine can hit 4.6ghz which should put it near 4th/5th place.
  6. Meaker@Sager
    Why not, can't hurt :p
  7. Mark J Foster
    It's official. This system is now ranked in 3rd place in Passmark's Top 20 Fastest Laptops page! The only two systems that are faster use K-type (overclockable) CPUs, while this one runs a 9750H with its RTX 2070.
    For those who are interested in trying it out, note that Passmark does require some O.S. tuning to get the best results, but it's definitely a lot of fun.
    Cheers!
    Mark
  8. Johannes.B
    Johannes.B Newbie
    Anyway we can get the Premamod bios for the clevo PB51?
  9. Mark J Foster
    For those who don't like Passmark, it's interesting to note that UserBenchmark rates this system at 97th Percentile (out of 100, only 3 systems with the same components would exceed it). On any benchmark I've run, this is truly an extremely fast machine!
  10. McNutter.
    McNutter. Newbie
    Been messing around with my PB51RF-G for a while. Here's some tweaks to the memory that might help others with the same RAM (2x8GB Corsair Vengeance 2666). All done with the default timings and voltage:
    Default 2667MHz (133x10)x2 = 38GB's memory bandwidth
    Better (overclock) 2993MHz (133x11)x2 42GB's memory bandwidth
    Best (overclock) 3000MHZ (15x10)x2 43GB's memory bandwidth
    Also spent HOURS with the MSI curve editor. This curve elimates 99% of the power limit throttling in games (still gets odd minor flickers during 3DMark but that's not a realistic load). Memory is set to +300MHZ BTW.
    Compare link (Discrete mode but with G-Sync off): https://www.3dmark.com/fs/20398647
