S96S how do I get webcam to work?
Discussion in 'Asus' started by blast00, Oct 2, 2007.
  1. blast00
    blast00 Notebook Geek
    How do I get my built in webcam to work in programs such as AIM or any messenger program? When I press the video chat button, nothing happens.. they can not see anything :(
  2. csky12
    csky12 Notebook Geek
    I am having problem with the webcam as well...I have the program VideoView and it only capture video, and i can't find the program for just picture taking
    anyone help?
  3. satdog
    satdog Notebook Evangelist
    did u guys download the Azurwarewave camera driver from intel website for the notebook? It comes with a program called AMcap.exe and u use that to take pics ,video etc
    i have Azurewave, GL860 and it works perfectly with the drivers from intel website
  4. blast00
    I have AMcap.. it came preinstalled on my laptop, but I still cant get the webcam to work in messenger programs.. The webcam itself works, when I run AMcamp but that isnt video chatting... what am I missing?
  5. Simpleofmind
    Simpleofmind Notebook Guru
    From what I know, there are two models to the webcam. There's the D-Max and there's the Azurewave. If you have the D-Max model, the AmCap will work but won't capture any pictures or videos. If you are looking for the drivers, try intels site for the Azurewave. If you looking for the D-Max, there's a post on this site that has the drivers. I have the D-Max and I can't get AmCap to capture video or pictures. My friend has the Azurewave and it works fine on his but the picture quality looks better on the D-Max.
  6. blast00
    my webcam works fine, and captures video when I use AMCap but it captures the video in AMCap, its not like a live feed into video chatting... Do I need to run AMCap while I video chat??
  7. Geared2play.com
    Geared2play.com Company Representative
    first of all the camera does not even work unless you install drivers manually
    1. browse the driver cd for the camera folder
    2. install the driver from the cd rather then from the autorun menu.
    i dont recall which driver from the cd is the right one becuase it has 2 of them. install them both. one will work. Your issues with messenger should be fixed after that
  8. blast00
    So I went into the camera driver folder, I tried to install the one for azureware I got an error: can't find language.ini
    I tried to install the driver from D-max I get an error installation failed
  9. Geared2play.com
    make sure you go to the proper folder for the right os. It works fine on my side
  10. blast00
    I did. still error... do I have to run AMCap when I am using messenger?
