Ryzen 7 4800H overheating in games!
Discussion in 'Hardware Components and Aftermarket Upgrades' started by weareandrei, Feb 9, 2021.
  1. Papusan
    Thermalright TFX, ICD, Phobya NanoGrease Extreme, Gelid GC-Extreme, Kryonaut Extreme, Coolermaster Master Gel. See if you can get the one in bolded text. I prefer Liquid metal (Grizzly Conductonaut) but if you go that route then read you up. Search Liquid metal in the forum. Put in @Papusan @Mr. Fox @Falkentyne in your search. Here is a link for you to start with http://forum.notebookreview.com/thr...nd-apply-traditional-and-liquid-metal.806840/
  2. Phoenix
    Phoenix Notebook Enthusiast
    Papusan likes this.
  3. KING19
    KING19 Notebook Deity
    I'll say do another repaste with a different brand. i might have to do the same eventually because lately when playing games my temps will spike as high to 97C but then drops back down in the 70C - 80Cs range and my GPU temps reached to the low 70Cs even with the overclock so i think its fine. I repasted with SYY-157 about 2 months ago and i probably didnt put enough on the CPU i guess, I dont wanna repaste the GPU too since the temps on it are fine.
  4. Deks
    Deks Notebook Prophet
    Thermalright TFX would be the best to use.
    Depending on the CPU die, I'd recommend using the X method of thermal paste application on a square die... and a line method on a rectangular die.
    That should work fine.
  5. KING19
    @Phoenix
    Update: I decided to do another repaste especially on the CPU and i got it right this time. I used the line method instead of the rice grain method on the CPU and there was a massive difference. When running Cinebench R23 i ended up with a score of 11660 and my CPU temps only reached to 92C when running on performance mode. I would suggest to repaste again with MX-4 if it'll make a difference or use a different brand.
  6. Phoenix
    That's awesome. I'm more curious about your heatsink tighening method than your paste method.
  7. KING19
    Nothing special. After putting the heatsink back on i press on it and then tighten the screws 1-6, for modern heatsinks it's normally fine but to be completely sure you have even pressure you can do 1 full turn on each screw and repeat until they're fully tight.
    Papusan likes this.
  8. Phoenix
    You must have gotten really lucky and positioned your heatsink in just the right place... I don't know what I'm doing wrong but I can only score 10,000 on cinebench and my cpu is thermal throttling. I've repasted at least 6 times.
  9. Phoenix
    I ordered a new heat-sink from lenovo and have some grizzly kryonaut on the way... I'll report the results here in a few days.
    Hopefully it fixes my thermal problem.
  10. KING19
    Im not sure about that, i usually put it in right every time. This time i used more paste and the line method and it worked out better than i hoped. Even in games my CPU temps only reached to 87C after an a hour of playing RDR2. You could try spreading the paste on the CPU dye until its fully covered. Like i said i used SSY-157 thermal paste which i heard it was a good paste, I hope your new heatsink and paste will help solve it.
