Running Mk6 just with charger
Discussion in 'Panasonic' started by Liteace, Aug 11, 2017.
  1. Liteace
    Liteace Notebook Consultant
    Im using my CF-19 Mk6 more for doing a bit of work in the eves, just a question, is it OK to run it without battery,just on mains supply just worried about damaging internals if no battery is there
    Thanks
  2. BaRRmaley
    BaRRmaley Notebook Deity
    Use dummy battery for your task.
  3. Liteace
    OK thanks, next question what is dummy battery and where would I get one
  4. toughasnails
    I have used a CF-51, 52 and a 19 on just main power with no battery installed and it worked great
  5. safn1949
    safn1949 I'm sure I'm on the wrong planet
    Battery is not necessary to run a laptop, my friend has 2 CF-31's and a CF-19Mk4 all minus batteries as they stay plugged in.
  6. BaRRmaley
    You can do it yourself. Just take a bar of lead and a rasp :)
  7. CWB32
    i have run all my panasonic laptops as well as others without batteries installed ... no ill effects other than loss of data if the power fails .
    "dummy batteries" are available for certain types of laptops or come as part of demo/display units for portable power equipment .
    yes , people have been known to steal batteries from those laptops (as well as power tools and such) that you see in walmart , home depot , lowes , best buy , etc .
    some of those displays of automotive/marine batteries are just empty shells or thin plastic mock-ups of their real counterparts ...
    can you imagine the lawsuits that would happen if some kid or adult managed to drop a real battery 3-4 feet onto their toes ?
  8. SHEEPMAN!
    SHEEPMAN! Freelance
    If the mains flicker, your work completely disappears.
    Battery = peace of mind.
    toughasnails likes this.
  9. ADOR
    ADOR Evil Mad Scientist
    If I am just messing around and it will be on long term on the charger I usually pull the battery to keep it in better shape, no problems yet on any toughbook doing that.
  10. SHEEPMAN!
    SHEEPMAN! Freelance
    Totally agree Paul but what if you are overcome with a desire to upgrade or something.....or send a letter to someone?
    Will you remember to save periodically?
    My power company is very touchy...over-voltage shuts down instantly to protect the system. (Off grid)
