RTX v RTX Max Q?
Discussion in 'Gaming (Software and Graphics Cards)' started by Cariblo, Aug 11, 2019.
  1. Cariblo
    Cariblo Notebook Consultant
    Ok so have been looking around a bit and I think I will lean towards a 2060rtx as it is a tiny upgrade but won't have me spedig crazy amounts. I am tempted with these so far:
    MSI GS75: https://www.overclockers.co.uk/msi-...n-bezel-i7-8750h-gaming-laptop-lt-29q-ms.html
    or
    HP Ome 17 which seems to come for more bang for your buck: https://www.overclockers.co.uk/hp-o...z-intel-i7-9750h-gaming-laptop-lt-04a-hp.html
    Alternatively this 2070rtx does soud good: https://www.overclockers.co.uk/msi-...3-144hz-i7-9750h-gaming-laptop-lt-29j-ms.html
    Also there is no Max-Q option for the 2060 right?
    Edit: does ayoe know why the HP omen is so much cheaper than other laptops in its range? Is that due to companies like MSI ad Razor where you just pay for the name?
    hmscott and NuclearLizard like this.
  2. NuclearLizard
    NuclearLizard Notebook Deity
    The omen seems to have less side features than the MSI, though yea you still pay a bit more for the name as well.
    Also depending where you live there might be a higher tariff on products from MSI than like HP or the like.
    Sent from my LM-Q710.FGN using Tapatalk
    hmscott likes this.
  3. Cariblo
    Ah thought so! Ok last question I promise! What do you thik of that MSI GE75 with the full RTX 2070?
    hmscott likes this.
  4. JRE84
    JRE84 Notebook Deity
    I owned a ge laptop.
    best keyboard I ever used and loud speakers, one problem was the cpu temps, i would check out a review to see if the new msi laptops overheat. if i recall correctly they don't.
    Pros: like 4 areas for storage upgrade
    killer speakers
    msi keyboard with per key rgb backlighting
    full 2070
    6 core cpu that doesn't throttle
    good srgb coverage on the high refreshrate display
    cons:
    rubbish trackpad
    rubbish webcam
    hmscott likes this.
  5. Cariblo
    Not bad for cons! I looked up some reviews ad heatinng seems fine.
  6. NuclearLizard
    I have a GT series and my brother has a GE series. Both have been solid so far.
    If the reviews reflect it I would go for that one.
    You will get a bit of a perf bump
    hmscott likes this.
  7. Cariblo
    Awesome thanks! Overclockers uk have it for order this week so might pick it up!
    hmscott likes this.
  8. Felix_Argyle
    Felix_Argyle Notebook Consultant
    Be careful with MSI stuff, especially the display hinge. The sockets that holds the hinge screws are metal but they are surrounded by cheap plastic which may crack in less than a year. At least this is what happened to some MSI owners before, I don't know if MSI did any improvements or not. You can Google the "MSI broken hinges" and see the affected models.
    hmscott likes this.
  9. Cariblo
    Hmm that's quite worrying as this is the reason I have to replace my current laptop. I am also considering the Asus Roc 2 or 3. What do you guys think of that?
  10. JRE84
    I wouldn't worry as some users have reported that playing football with their laptops decreases lifespan...don't worry all laptops can break down and do, msi tests all their machines for repeated use.
    hmscott likes this.
