RTX 2080 in P870TM1-G
Discussion in 'Sager and Clevo' started by Hterag, Feb 27, 2019.
  1. lsflp
    lsflp Notebook Geek
    I buy from Eurocom, and I mod the heatsink
    PerryMason and jfrancis232 like this.
  2. jaybee83
    jaybee83 Biotech-Doc
    DUDE! populate that second RAM slot ASAP! running single channel RAM with such a config is a scandal! :D
    lsflp and joluke like this.
  3. Meaker@Sager
    It's certainly the fruit on the lowest branch while you are struggling to reach the top of the tree.
    lsflp and jaybee83 like this.
  4. lsflp
    lsflp Notebook Geek
    Yes, I know the problem, but Monday will be solved.
    And the video card its amazing. easy mod.
    PerryMason, jaybee83 and sicily428 like this.
  5. PerryMason
    PerryMason Newbie
    Hello my friend! Tell me, please, what model of Clevo do you have? What BIOS version was used? I'm really looking forward to the installation instructions. Thank.
  6. PerryMason
    PerryMason Newbie
    Hello! What version of BIOS is installed? vBios is installed standard (visible version of the BIOS on the label of the video card). Cooling need to cut with a file?
  7. clevo-extreme
    clevo-extreme Company Representative
    You need mod bios as well for rtx gpus. But rtx 2080 into this chassis is too complicated.. Heatsink must be modified. Something with cutting and rebuilding I don't know exactly.
    Fastest Customizable Gaming Notebooks & Mobile Workstations | CLEVO Integrator
  8. Csupati
    Csupati Notebook Enthusiast
    Hi , if I have already the modded bios ( 8700 fits perfect) , still need another bios or this bios will work with rtx cards?
  9. Meaker@Sager
    The bios needs some work on the RTX cards from what I understand. This is separate from the CPU.
