RTX 2080 in P870TM1-G
Discussion in 'Sager and Clevo' started by Hterag, Feb 27, 2019.
  1. Johnksss
    Johnksss .
    I guess....If it did, they would be selling it by now. And it would be out in the wilds working 100 percent correct. The P870 seems to work differently from the P775. So it makes sense to see why Clevo dropped support for it and ran with the P775 instead. Even though the P870 would have been the far superiority choice, due to it's cooling head room. It's not just the 20 series cards not working, but on stock bios the 9900K is suspect. And a very simple change in the bios can in fact brick the machine. A hard crash can also put the machine in to a world of hurt. I think @clevo-extreme may have experienced this. (Speculations of course)
    @Prostar Computer
    Correct, but I can't say for sure because someone may have fixed it, but i'm a bout 99 percent sure it's non functional.
  2. clevo-extreme
    clevo-extreme Company Representative
    We have received just normally screen. But card is very hot as well. We have latest available bios with 9th gen compatible.
    Fastest Customizable Gaming Notebooks & Mobile Workstations | CLEVO System Integrator
    PerryMason, FTW_260 and Johnksss like this.
  3. Meaker@Sager
    Interesting results though the 1080 still does very well in the machine so not really tempting to those owners.
  4. Hterag
    Hterag Notebook Enthusiast
    Is that a setting change in the BIOS that can brick it? Or do you mean flashing a slightly different one can brick it?
    Are you saying you are running the latest Clevo BIOS in P870TM and it works with the 2080 and 9900K?
    In any case, I'll have to find a creative way to beg @Prema for a BIOS... I can't sing a song or bake a cake, that's already been done...
  5. Johnksss
    Johnksss .
    And does the bios has a recovery? Does FN+D work? Removing the cmos battery, does that work?
    I'm running the latest Premamod version. Clevo did not have a 100 percent functional one and no plans on making one.
    And @Prema will not make personal versions for non partners unfortunately
  6. Meaker@Sager
    Yes no RTX gen update from clevo officially.
  7. clevo-extreme
    P870KM i9-9900K RTX is 2070[​IMG][​IMG][​IMG][​IMG][​IMG]
  8. Hterag
    How did you do that? Are you using a modded BIOS or the stock? Is it just the 2070 that works? What about the 2080?
    PerryMason likes this.
  9. lsflp
    lsflp Notebook Geek
    PerryMason, joluke and jaybee83 like this.
  10. jfrancis232
    jfrancis232 Notebook Enthusiast
