RTM875t-606( Info gathering and OCing)
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Darth_nVader, Oct 28, 2009.
  1. pyfgcrl
    pyfgcrl Notebook Enthusiast
    Is the clock generator button really PLL information? I thought PLL information would come out of the SMBus button.
  2. advan20092
    advan20092 Notebook Guru
    Yes it is really PLL registers. I've compared with SetFSB
  3. pyfgcrl
    Oh, excellent... so I have an RTM875T-606 and my output is
    Code:
    41 88 FF FF FF 00 30 1E 10 65 7D 00 0D
    do you know if there's something there I can change to alter FSB?
  4. advan20092
    There should be 30h bytes instead of 13d. SetFSB changed a lot of them to increase speed. I've changed 0e and 1f bytes to do so. Try edit rw.ini to allow all bytes to be displayed
  5. pyfgcrl
    Awesome. My hp Pavilion dv9700t with T9300 (2.5GHz) Penryn has been successfully overclocked to 3.13GHz!
    cpuz_1054069-1.png cpuz_1054069-2.png cpuz_1054069-3.png realtemp_T9300_250x12-5.png
    Steps:
    1. Executed pin mod to TME (pin 4) on RTM875T-606 as illustrated by me here, thanks to moral_hazard, nando4, darnok44 and Darth_nVader as described here. This step actually might not have been strictly necessary, but I'm glad I did it - I'd really like to see if I can get some sort of micro-adjusting FSB tool to work... maybe then I could go even higher than 250MHz FSB!
    2. Modified RAM SPD settings with SPDTool 0.63. I used Thaiphoon Burner 6.7.0.0 for advice on changing the latency parameters, and then SPDTool to fix the checksum and burn them into the module. This was all done on an old 1GB Samsung module to test (so if I screwed up, I wouldn't care so much) and now that it's working, I'm going to mod my Crucial (Micron) 2GBx2 sticks -- UPDATE: That didn't work due to the modules' SPD EEPROM being hardware write-protected, so I used two G.Skill 4GB SODIMMS instead, which did work. Details are here.
    3. Downloaded custom RTM875T-606 overclocking tool based on SetFSB, found here.
    4. Ran the executable OC_RTM875T_250.
    5. Voila! T9300 running at 3.13GHz (max temp 70°C) stable enough to run BOINC at 100% CPU for 25 minutes now while I wrote this all up. :) By the way, IDA is 3.38GHz :D
  6. mujjuman
    mujjuman Notebook Deity
    wow dude thats awesome
  7. sirgrinalot
    sirgrinalot Newbie
    So is it safe to assume that this method will not work with the RTM875N-606 square realtek pll chip?
  8. lmkong
    lmkong Notebook Enthusiast
    If your system FAILS..............STOP, you need to try and setup the PIN17/18 Pin Config (I'll add a table for this later if we have anyone that needs it, post a reply to this topic.)
    could you add the config
  9. tanjo-15
    tanjo-15 Newbie
    Hi all.
    I tried this mod on my aspire 8920g and it worked a treat.
    Just grounded pin 4 of rtm875t-606 to ground.
    Then i ran set fsbset and slowly ramped the cpu to 2.6 gig and is still very stable.
    My notebook has the t8300 in it.
    hope this helps.
  10. User Retired 2
    RTM875T-606 / RTM875N-632 datasheet
    Did anyone ever obtain a RTM875T-606 datasheet? I am specifically looking for info on the RTM875N-632 variant. This is the PLL visually identified to be in a i5-430M Compaq CQ41. I contacted setfsb's abo requesting access to it. Abo offered no level of support without a 'donation'.
    So atm I'm not sure if the RTM875N-632 can even be overclocked.
    The good part:
    * the TME bit, register 09, bit 6, is disabled
    * register 7 is 0x1E indicating it is a Realtek PLL
    The not-so-good part:
    * quite a few of the other registers are 0xFF which may mean it is not overclockable. Certainly differs to the RTM875T-606 screenshots posted earlier in this thread.
    * the RTM875T-606 specific setfsb binary doesn't do any overclocking on the RTM875N-632.
    * selecting any of the other Realtek PLLs in the freeware setfsb altered the CPU clockspeed or made any difference to system performance.
    Image: RTM875N-632 PLL registers
    With no datasheet at hand, can any RTM875* guru have a look and make any suggestions?
