Router damaged... how to connect without it?
Discussion in 'Networking and Wireless' started by Nocturnal310, Apr 3, 2008.
  1. Nocturnal310
    Nocturnal310 Notebook Virtuoso
    Hi,
    my router is damaged.. will get a new one after 2 days.
    Can someone tell me how to connect to Internet without the wireless router?
    I have two cables coming out of the wall.
    both a 2 pin --dial-up cables.
    one for Phone & one for internet.
    WOuld appreciate some help
  2. Thomas
    Thomas McLovin
    Connect them to your laptop.
    What kind of internet do you have?
  3. Nocturnal310
    I have the WLAN network.
    All comps connect to the internet via Wireless Router.
    SO the router is dead.
    i am sitting with my laptop next to the Wall from where a Telephone wire comes out which goes inside the Router.
    How to use that wire to connect to the internet?
  4. hehe299792458
    hehe299792458 Notebook Deity
    are you saying the modem is dead or the router?
  5. Nocturnal310
    look...
    The 2Wire Wireless Router is not with me now....
    I wanna connect to the internet ..
    How do i connect to the internet without the Wireless Router?
    There is a Telephone wire coming out of the Wall which is connected to DSL filter.
    So now how do i use that wire to access high speed internet?
  6. Nocturnal310
    Before:
    Laptop---->Wireless Router-----> Internet
    Now:
    Laptop---->Internet???
  7. TonyZ
    TonyZ Notebook Evangelist
    If it is DSL, the wire coming from the filter (from the telephone socket) that used to be in the wireless ADSL Router (with in built modem) will now have to be plugged into a seperate USB/LAN MODEM.
    Your ISP should have supplied you with a MODEM. If you bought the wireless router modem by yourself then you may have the seperate modem packed away somewhere.
    Unfortunately if the wireless router came free with your ISP, then you cannot access the internet until you get another wireless router with an inbuilt MODEM
  8. Nocturnal310
    What!!
    i used to think the standard Modem is in-built in most laptops now.
    You mean without the Wireless Router my entire Connection is wasted? i cannot use it without a Router?
  9. redrazor11
    redrazor11 Formerly waterwizard11
    Should be: Laptop --->wireless Router---->modem---->Internet
    (In some cases Router = modem)
    Then
    Laptop--->modem--->internet
  10. TonyZ
    What he said above.
    Also the 'MODEM' which comes with the ISP is usually fixed settings to connect to their network.
    Wireless Router (in-built Modem) has to be set manually using the settings provided by the ISP.
    Only Wireless Routers for CABLE MODEMS are 'just' Wireless routers with no in-built MODEM as the Cable company provides the CABLE MODEM which cannot be 'store bought'
    And to answer your question; yes you cannot connect to your internet without a modem or an ADSL wireless router. Laptops may still have built-in DIAL-UP modems but not broadband.
