ROG GL503VS repaste help
Discussion in 'ASUS Gaming Notebook Forum' started by jaka004, Mar 12, 2018.
  1. jaka004
    jaka004 Newbie
    Hello I am just wondering if anyone has any experience in repasting this particular model, since I couldn't really find any information online.
  2. skman
    skman Notebook Geek
    i saw this youtube video on a repaste for GL503..hope this helps!
  3. Kevin@GenTechPC
    What type of thermal compound are you going to use?
    To remove existing thermal paste, use WD40 mixed with a paper towel, simply wipe the surface with it then it should come off easy.
  4. jaka004
    jaka004 Newbie
    I am still debating on using LM since I need to carry my laptop from time to times, but my original though process is that I apply LM to gpu and cpu and the heatsink and for the other (chips?) I am not sure if I used the correct word there I use a paste that is not LM. Oh and doesn't WD40 leave a protective layer that stays on and could cause problems?
    Kevin@GenTechPC likes this.
  5. Kevin@GenTechPC
    It may leave a little bit of oil but if you want to get rid of that then use alcohol afterwards.
