ROG G75VW fans and battery replacement questions
Discussion in 'ASUS Gaming Notebook Forum' started by F34R, Dec 11, 2017.
  1. F34R
    F34R Notebook Consultant
    I'm looking for a new battery and fan replacements for this tough cookie. If the laptop is set in the normal use position, the fan that is located on the right side is no longer working. It tries to spin up, but it won't. The left side fan seems to be working just fine.
    So, do I use the orientation of the laptop in a normal position to say which fan is faulty and needs to be replaced? If I flip the laptop over, from left to right, then the left side fan becomes the right side, and vice versa lol.
    Also, any recommendations for a good battery. The stock one no longer holds a charge at all. :(
