RLECViewer: Custom Clevo Fan Control
Discussion in 'Sager and Clevo' started by Zuyang, Jun 17, 2018.
  1. Zuyang
    Zuyang Newbie
    Original post (in Chinese): http://tieba.baidu.com/p/4872453181
    The original program is in Chinese, I translated it into English (at least for the most part).
    Source code: https://github.com/duguzuyang/RLECViewer
    Installer: https://github.com/duguzuyang/RLECViewer/raw/master/Install/Product/RLECViewer.exe
    Uninstall Clevo Control Center first, then install this program.
    Tested on Clevo P751DM2, Windows 10 1803 w/ UEFI.
    Warning: Use at your own risk, no warranty whatsoever.
    This software was originally designed to make the laptop run quieter during normal daily usage, since the original fan curve is pretty aggressive in lighter tasks.
    oile, Cheddar, Vasudev and 7 others like this.
  2. bennyg
    bennyg Notebook Virtuoso
    Nice. I've only been waiting for this for like... the past seven years.
    Will be testing this.
    jaybee83 and Dr. AMK like this.
  3. bennyg
    So it works ok on W110ER (i7-3630qm/GT650M), which has only one fan. Lots of trial and error to find values that work for the individual laptop, for example this was on minimum actual fan speed until "45%" in the app. There's also a delay of a few seconds so if you set the % fan speeds too far apart you will end up with an annoying off-on cycle - I will be interested in trying it in the P870DM3 to see whether the fan speed ramp will be gradual like it is on the stock profiles
    On initial use I'd request more customisation (to set the number of steps and edit the temp thresholds), and multiple profiles that can be quickly changed (tied to hotkeys)
  4. Dr. AMK
    Dr. AMK Living with Hope
    Many will be very interested, waiting for any updates, thanks in advance.
    Vasudev likes this.
  5. Dr. AMK
    Nice finding, thank you for sharing.
    Vasudev likes this.
  6. jaybee83
    jaybee83 Biotech-Doc
    damn, that is some crazy stuff! clevo users have been asking for something like this for yeaaaars.... o_O :eek:
    Dr. AMK likes this.
  7. FTW_260
    FTW_260 Notebook Consultant
    Dr. AMK likes this.
  8. John@OBSIDIAN-PC
    John@OBSIDIAN-PC Company Representative
    Why should i answer anything? The more solutions we have the better! Hurray for this.
    I´ll keep doing my own version which hopefully will have more options then this one. But this seems cool already, way to go!
  9. Prema
    Prema Your Freedom, Your Choice
    Waiting patiently for yours!
    The above is replicating Clevo's own internal (read short therm) testing software and also has like zero safety net in case it looses control over the FANs.
    It'll smoke a system if user sets wrong values or it looses control and they no longer spin up higher with increased heat. Hence we used to call it the RMA Tool. ;)
    Papusan, Vasudev, steberg and 3 others like this.
  10. John@OBSIDIAN-PC
    I actually have not looked at that code, so i did not knew that.
    It´s weird that most of the solutions take that path.
    If you look at Control Center there is already a really cool DLL that exposes to WMI lot´s of methods for all sorts of stuff, setting fan / setting keyboard colors / etc.
    My method is using just that, with a high performance API i talk directly with the same dll that CC does.
    Users will be able to use the app with CC running or for those without CC the app will prompt to install only the needed dll. The app will be modular enough to use different methods for getting temperatures and loads too, either use Open Hardware Monitor or any other with wmi methods.
    So here is where i am at the moment:
    For "Automatic Modes" you can create and name 3, each will have a lookup table that can be edited with any file editor or in the app itself:
    (Note: This is a Debug version, no theme / colors / styling )
    Those "weird" numbers will be 0 to 100% in the user version.
    But it´s basically a lookup table, CPU Temp x GPU Temp.
    Useful for brands (like us) to create different automatic modes for each laptop model.
    As for the Manual Mode:
    You will have 8 ranges setup for CPU and GPU (individually).
    You can set ranges and fan speed for each range.
    At the moment i´m trying to figure out how to do some smart ramping and to give the user ramping multiplier slider, maybe i will call it "Ramp Up Speed" and "Ramp Down Speed"... not sure.
    TheChosen0ne, m4gg0t, matyee and 12 others like this.
Similar Threads - RLECViewer Custom Clevo
  1. lordmando
    523
