RivaTuner not working on newest W10. Any fix?
Discussion in 'Windows OS and Software' started by B0B, May 15, 2018.
  1. B0B
    B0B Notebook Deity
    The latest updates seem to have disabled RivaTuner.
    I have a new laptop i'm working on thermal testing and it's a pretty key tool for me. Any fix out there? There's no current beta either.
    EDIT: 5/16/2018 Just roll back to a previous W10 version till RivaTuner creates a beta. Problem temporarily solved.
  2. StormJumper
    StormJumper Notebook Virtuoso
    Did you contact the Hardware manufacture support before coming here about the issue? That would be the first contact.
  3. w3r3w0lf
    w3r3w0lf Newbie
    Dont know if it helps but i use MSI Afterburner 4.5.0 in Windows 10 with no problems.
    Make it a go and see if can do what you want
  4. senso
    senso Notebook Evangelist
    Same happened to me, just re-installed, and had to press the show Stats key, before the update it would always show up automatically, but now, every time I launch a game I have to press it(F12 in my case).
    Same for other games stats counters, they get hidden every time I launch them, still need to dig up why windows is doing this..
