Review: Sony Vaio SA
Discussion in 'VAIO / Sony' started by requiem86, Jun 7, 2011.
  1. DTN107
    DTN107 Newbie
    Anyone found a "real" driver for the webcam?
    The coloring from the webcam is sooo crappy. It is either very grey and grainy or other times it is very yellow.
    It seems a like a very common issue.
    I tried adjusting the settings but it isn't really working.
    Sony's website only has the Webcam software "Arcsoft webcam program".
    The driver being used is some generic microsoft driver from 2006.
    Seriously the quality from the webcam is so crappy.
  2. darxide_sorcerer
    darxide_sorcerer Notebook Deity
    someone uninstalled the ArcSoft software for the webcam and reported that it worked beautifully after that. maybe you can try that.
  3. noxis
    noxis Notebook Enthusiast
    Do you know if yours came with the "HD" webcam? As there are 2 types for the model when you spec it up yourself on the VAIO website.
  4. DTN107
    DTN107 Newbie
    It is the HD webcam yes.
    Exact model is VPCSA3AFX.
  5. APEXi
    APEXi Notebook Enthusiast
    After waiting 3 weeks now i got my new Vaio SA4 :)
    I installed an Crucial C300 250GB SSD, done a Win 7 x64 Ultimate installation from scratch - installed all Chipset and RST Drivers but RST shows only 3Gb/s.
    Bios Version is R2086H4 - did sony removed SATA 6 Gb/s support?
    THX
  6. darxide_sorcerer
    yes, no SATA III support on SA.
  7. jay_brubin
    jay_brubin Notebook Enthusiast
    does anyone get 3 minute periods where the OCZ SSD seems flooded and the hard drive light is constant...windows 7 freezes...?
  8. Theory
    Theory Notebook Guru
    Before I purchase a CTO SA from Sony's website, how does the internal battery work? Can I remove this battery easily? Also, which model comes with the finger print scanner? Does the SA come with it? Sorry if these questions have been asked before.
    Thanks!
  9. darxide_sorcerer
    yes, you can remove the battery very easily. and yes, SA has a fingerprint scanner.
  10. Theory
    Thanks so much for your quick reply! I was wondering if you can take pictures of the battery removal process. Thanks so much!
