[Review] Sager NP8651 / Clevo P650SE with GTX 970m HTWingNut's REVIEW
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by HTWingNut, Nov 15, 2014.
  1. StormFalcon
    StormFalcon Notebook Geek
    Could somebody tell me the difference between the P650SE and the P650SE-A? I know the second one has a Broadwell CPU instead of a Haswell but is one considered an update to another? Also would the P650SE-A still be a Sager NP8651 or not? Thanks
  2. Meaker@Sager
    No, Sager did not release the broadwell models so there is no equivalent sager model. The only difference is the different CPU soldered on but that has implications on the BIOS for instance.
  3. StormFalcon
    Oh because I have a P650SE-A Sager laptop. The CPU frequently hits 90 degrees celsius with no dust and Arctic MX-4. I heard that most heat issues are caused by warped heatsinks. Is there anyway to fix that?
  4. Trewhela
    Trewhela Notebook Consultant
    I had the same problem but with mx4, i repasted with ic7 and max of 80c !
    Enviado desde mi SM-G930F mediante Tapatalk
  5. Meaker@Sager
    I would try a fresh coat of IC diamond too :)
    You can check the contact pattern and see how good it is too, if you are not sure post a photo here when you remove the heatsink what the spread looks like.
  6. StormFalcon
    So my laptop doesn't exist?
    Sent from my Moto G (5) Plus using Tapatalk
  7. StormFalcon
    I thought TG Kryonaut was the best non-liquid metal paste?
  8. TomJGX
    TomJGX I HATE BGA!
    ICD is less likely to wear out quickly compared to Kryonaut... I personally have tried Gelid GC Extreme, ICD, MX-4 and won't use anything other than ICD!
    steberg likes this.
  9. Meaker@Sager
    Sager use NPXXXX model type numbers. Which is yours specifically?
  10. StormFalcon
    I bought a NP8651 through Xotic but Sager was taking awhile so the sent me a P650SE-A with a 5700hq.
