[Review] [CPU and GPU Temperatures] - Clevo P775DM2/3(-G)/P75xDM2(-G) (Sager NP9152/NP9172)
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by iunlock, Sep 6, 2016.
  1. iunlock
    iunlock 7980XE @ 5.4GHz
    Greetings,
    Please copy and paste the format below and post your temperatures as many are curious about the Skylake and Pascal (specifically the GTX 1080 chips) and how they do temp wise in these beasts.
    * Feel free to tweak the post to your liking as the main point and purpose here is, "Organization." We're not noobs here... :)
    Guidelines:
    • CPU: OCCT
    • GPU: FireStrike | Unigine Heaven
    • Temp Monitoring App: HWiNFO64
    • Notebook is to be placed on a flat surface without any laptop cooler.
    • The rear of the notebook may be lifted.
    • This is not a race or a competition.
    -------------------------copy/paste below----------------------------
    Machine Specs:
    CPU: 6700K
    GPU: GTX 1080
    CPU Thermal Paste: Stock (ICD)
    GPU Thermal Paste: Stock (ICD)
    ________________________________________
    Ambient Temp: 23C
    CPU Stock Clocks (Bone Stock Run):
    OCCT
    • CPU Max Temp (Stock Fan Profile): 99C
    • CPU Max Temp (F1 Fan Profile): 99C
    CPU Modded / Tuned / Over-Clocked / Under Volted:
    OCCT
    Notes: The CPU is Delidded and Repasted with Grizzly Conductonaut on the die->IHS, CPU & GPU.
    • CPU Max Temp (Stock Fan Profile): 68C
    • CPU Max Temp (F1 Fan Profile): 57C
    • Volt +/-: -225mv Core / -225mv Cache
    • F1 Fan: ON
    GPU Stock Clocks: Unigine Heaven
    Notes: This is after the Delid and Repaste.
    • GPU [1] Max Temp: 69C
    • GPU [2] Max Temp: N/A
    GPU Over-Clocked:
    • GPU [1] Max Temp: ##C @ ####MHz
    • GPU [2] Max Temp: ##C @ ####MHz or N/A
    Links / Screenshots / Scores - Benchmark Scores/Validation:
    • HWiNFO64: (Post screen shots showing temps.)
    • FireStrike:
    • TimeSpy:
    • Cinebench R15:
    • OCCT: (30 minutes minimum.)
    • Gaming: (Game, Settings, Duration...)
    Notes:
    Please provide any additional info. that you would like to share. Ex. "I've tried CLLU / GC (Liquid Metal), but the heat sinks seem to be warped so I switched to traditional paste"...etc...
    Organization is key and I hope this helps others who are seeking this info.
    * If there are any additional categories or info that you would like to see added, please let me know and I'll update the OP.
    Cheers
    Dr. AMK, Preludesh5, Ashtrix and 5 others like this.
  2. iunlock
    Below is a ~30 Minute OCCT Test on my P755DM3.
    Test Type: (Straight Out Of The Box Test)
    Joining the 100C Mile Club....
    FireStrike: First Run.
    Unigine Heaven: Max Everything @ 1920x1080.
  3. iunlock
    After some adjusting, these are my temps while:
    • Running OCCT
    • Under Volting to -225mv on both the Core and Cache
    • F1 Fan ON
    Check out the Temps, VID and Package Power.... Great MPG...
    CPU Avg:
    • Core #0: 55C
    • Core #1: 56C
    • Core #2: 52C
    • Core #3: 52C
    VID Avg:
    • 1.066V
    CPU Package Power:
    • 58.444W
    Johnksss likes this.
  4. i_pk_pjers_i
    i_pk_pjers_i Even the ppl who never frown eventually break down
    I wish this thread was more active, it has a lot of potential.
    hmscott and iunlock like this.
  5. Mr. Fox
    Agree, could be really useful.
  6. TBoneSan
    TBoneSan Laptop Fiend
    I'll add once I have my machine. It would be good to make this into a google docs spread sheet.
  7. iunlock
    Yes indeed. If we can get a selected few to share a google doc spread sheet, that would be great.
    i_pk_pjers_i likes this.
  8. Benmaui
    Benmaui Notebook Evangelist
    I will also add to this once I get my machine, sadly mine is still 4 weeks out because of the 120hz gsync screen, it is being assemble in China as we speak though, fingers crossed I win the silicon lottery, and get a perfect heatsink :D
    It will also have Prema bios because I'm buying through a Prema partner .
    hmscott and Cass-Olé like this.
  9. sirana
    sirana Notebook Deity
    Does DreamMachines also flash it remotely for you? Because as of now it is not available I think.
  10. Benmaui
    I was told that it should be done by then, 4-5 weeks, and it would be on the laptop when I receive it, dunno if this will actually be the case or not, I'm guessing only brother @ Prema would know if it will be done by then . ^^
    sirana likes this.
