[Review] Clevo/EVOC PA71ES-G
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by LeiEn, Jun 5, 2018.
  1. Meaker@Sager
    Our site offers manuals and drivers too.
    Papusan likes this.
  2. Sonnie Parker
    Sonnie Parker Notebook Consultant
    Not happy with my Clevo... sending it back and will pay the restocking fee. Just running Firefox and Postbit email client and the fans constantly run and a lot of heat emits from the unit. Very disappointed that a $2,500 laptop isn't any better than this. Bummer... but it is what it is.
  3. Meaker@Sager
    Sounds like a power setting issue if the air is coming out hot and it's using a lot of power. Either the dedicated GPU is being activated by mistake or the CPU is set to high performance.
  4. Sonnie Parker
    Balanced power setting. Not sure about the GPU.
  5. Meaker@Sager
    During web browsing it should be quiet.
  6. vIkInG_w0w
    vIkInG_w0w Notebook Consultant
    Just in case it's a power issue, how do i resolve it?
  7. Meaker@Sager
    You can check if your GPU is active in the Nvidia driver control panel, under the desktop tab at the top click to enable the usage indicator. A quick program like CPU-z will show you if your CPU is clocking up beyond basic 800mhz - 1.2Ghz kind of idle speeds.
    Vasudev likes this.
