[Review] Clevo/EVOC PA71ES-G
Discussion in 'Sager/Clevo Reviews & Owners' Lounges' started by LeiEn, Jun 5, 2018.
  1. vIkInG_w0w
    vIkInG_w0w Notebook Consultant
    Can anyone guide me on how to disable wake on lid open on this laptop?
    I have set "Choose what happens on lid close" to "Do nothing" on both Battery and Plugged-in in Power Options. A solution I got when I searched for it was to go to Device Manager > System Devices > ACPI Lid > Power Management > Uncheck "Allow this device to wake the computer" but I have no such Power Management tab there.
  2. Elvin1396
    Elvin1396 Newbie
    So I installed equalizer and viper, and I honestly don't notice a difference in sound volume or quality. Anyone else experience this as well?
  3. Meaker@Sager
    Have you adjusted the settings?
  4. trey22
    trey22 Notebook Consultant
    Have this laptop in the way, but what I really need to know is, since it has switchable graphics... Will it run an external monitor through the GTX1070? I’m planning on using an Acer X34 (newer version) @ 2K @ 120Hz w/ G-Sync.
    If it won’t, it’s refuse delivery or return unopened.
  5. Meaker@Sager
    The external outputs are hooked into the dgpu directly, g-sync etc is supported through them.
  6. trey22
    WHEW... Thx @Meaker@Sager! This laptop is for a friend and arriving tomorrow so I can configure it for him. He also bought a Acer x34, so I get to "borrow" it until I take everything over to his house to set up :D.
  7. Meaker@Sager
    No problem, the switchable part is just for the internal panel. The thought is if you have a monitor plugged in you are likely near a power outlet anyway.
  8. Plinius
    Plinius Notebook Enthusiast
    Hi, may I ask how the 2 x M.2 are wired ? 2 lanes or 4 lanes and is the (optional) thunderbolt 20 or 40 ?
    ad keyboard: white backlit vs rgb
    is the white backlited good enough to work in the dark ?
    thanks.
    ps reading here since months and still dont know what to buy lol
    but Im getting closer
  9. Meaker@Sager
    Thunderbolt is full speed. M.2 is 4x (though usual chipset max 4x total applies). Keyboard is RGB and combines for white. Yes it is bright enough in the dark.
    LeiEn, Vistar Shook and Vasudev like this.
  10. Plinius
    thanks for reply :)
