Restore my CF-18 MK1 Error #49 write fault ?
Discussion in 'Panasonic' started by toughasnails, Aug 14, 2011.
  1. Toughbook
    Blair,
    I had this issue once myself. I had to try three times to get it to load in a CF-18. How long are you waiting when it hangs? I finally let mine sit for 10 minutes or so and it installed.
    You can try swapping the RAM and/or the wifi card...
  2. toughasnails
    Rick, the last time it sat for about 1 hour and no go. I did finally get it installed but when I try to update it. it fails or crashes...blue screen and restarts. I have run scans on the harddrive and found no errors so like you say ram or the wifi card is left. I am going to run a memory test later to see what that turns up. Will update then.
  3. toughasnails
    My memory was no good, ran memtest86 and it failed so I dropped another stick in it and run the memory test with no errors. So far it has downloaded all updates and SP3 which before it would crash (blue screen) so all is well. :D
  4. Toughbook
    Good to hear!
  5. Doobi
    Doobi ToughBook DeityInTraining
    NICE!! Glad you stuck with it Blair!!
  6. ffergie
    ffergie Notebook Enthusiast
    Good for you...... Guess that means that neither the laptop or you get thrown against the wall???:D
  7. toughasnails
    :laugh: :laugh: That's right
