Restore my CF-18 MK1 Error #49 write fault ?
Discussion in 'Panasonic' started by toughasnails, Aug 14, 2011.
  1. toughasnails
    Well I am trying to restore my CF-18 MK1 and I keep getting Error #49 write fault I figured maybe the disk 1 was bad but got another one and still get the error at 17% .
    Well so far I have tried 5 harddrives, 2 different cd enclosures, 4 cd drives, another caddy and I even tried to use a XP Pro OEM disk and I get to 19 minutes remaining in setup and it just stays there " installing start menue"...think thats what it says :confused: Any ideas guys
  2. ffergie
    ffergie Notebook Enthusiast
    Blair:
    I had an issue something like this a while back and it turns out something had corrupted my Master Boot Record. Once I did a format MBR, the install went off without a hitch. Doesn't make sense as I think the MBR is on the hard drive. But......... something about the failed install corrupting the MBR??
    It worked for me.
    BTW, missed out on a $250 CF-19 yesterday in Skowhegan; if you can believe it, the guy said that it sold real quick!?!?!?!?!?
    Frank
  3. KLonsdale
    KLonsdale Notebook Evangelist
    The fixmbr command in the recovery console has save me several times from my misadventures.
  4. toughasnails
    Well that bites :eek: . The lowest I have seen them is $500 but have been in not the best shape. I will send you a PM in a few days about the 19's :)
  5. toughasnails
  6. SHEEPMAN!
    SHEEPMAN! Freelance
    Blair,
    Somewhere in here is a post that describes I think he used four different drive manufacturers before one took. You've probably seen it.
    Did you set to defaults...pull battery and power and hold the switch till your finger got tired. Maybe un-plug the cmos battery too?
    How bout running a Linux Live CD? Using a different USB port? Throwing it against the wall? :)
    Jeff
  7. toughasnails
    I got close to that last night but the girlfriend told me if I did that I was going to find out what it would feel like too :eek: trust me she could do it...ffergie knows her...he would agree :D
  8. ffergie
    :nah: I'm drawing the line at discussing laptops, not girlfriends; I might stay out of trouble following that rule.
    But, Blair, I would not throw the lappy if I were you; it would probably fare better than you would. :wink:
  9. Doobi
    Doobi ToughBook DeityInTraining
    I would wager the on board RAM is probably toast. Can you run MEMTEST on it?
    Rob would probably know, but I do believe that at the percent complete, it start loading the program files into RAM to begin the install process.
  10. toughasnails
    I think you might be right, after messing with it all day I did get XP loaded but had about 4 crashes " memory dump" so I need to dig up some memory. Will let you know when I get some.
