[Resource] Index of Links to Helpful Threads and Posts (See Post #1 for Index)
Discussion in 'Alienware' started by Mr. Fox, Feb 25, 2012.
  1. Mr. Fox
  2. Mr. Fox
  3. ForestEX
    ForestEX Notebook Guru
  4. Mr. Fox
    Good idea, ForestEX. Done!
  5. Mr. Fox
    New links were added to the index in the opening post:
    • M18x R1 Upgrade > M18x R2 Motherboard
    • Killer Wireless Discussion Thread - Look for Solutions and Ask Questions Here
    • Sound Blaster Recon3Di Discussion Thread - Look for Solutions and Ask Questions Here
  6. Mr. Fox
    One of the leading causes of poor performance with computers, especially high performance gaming systems, is the accumulation of dust and lint in the fans and heat sink radiators. A small amount of crud can cause huge problems with overheating and adversely affect performance in a dramatic way. Because their cooling systems are not as robust, the effect on laptops can be even more dramatic.
    The instructions in the Service Manual are for part removal, not "cleaning" and you simply follow the instructions for removing the appropriate parts. Below (inside of the spoiler) are the steps directly from the service manual. You can skip step 4 for the processor and video card fans, as there is no need to unplug the wiring for the fans. This is a fast and simple procedure.
    And, if you have a vacuum cleaner, there is no need to run out and buy a can of compressed air. If you are a noob at working on computers, ground yourself to the chassis of the computer before touching any components inside of it. This will discharge static electricity. Simply touch a screw head or the metal connectors for the system battery. Don't let this scare you. It is a very simple task and you will be amazed at how easy it was. (I have been working on computers 25 years and have never damaged a part by static discharge, but I am always careful about grounding myself to the chassis before I start handling things on the interior.)
    Be sure to use a screwdriver that has a tip that fits snugly into the Philips screw. If you use one that is too small it may strip the screw head. You can buy a jewelers screwdriver set for next to nothing at common places like Walmart, even Walgreens Drugstores. It is normally the largest screwdriver in the jewelers screwdriver set that fits the screws best.
    Note: the images below are hyperlinked to the corresponding pages of the Service Manual.
    Those GPU temps are higher than ideal for your system being idle, but what really matters is load temps. So, those numbers do not mean a lot while your system is not under load.
  7. Mr. Fox
  8. Mr. Fox
  9. Mr. Fox
  10. Mr. Fox
    Power Drain:
    • Remove system battery
    • Disconnect AC adapter
    • Hold power button down 30 seconds
    • Connect AC adapter
    • Load Windows
    • Install system battery
    Clear CMOS:
    • Remove bottom cover
    • Hold down power button for 30 seconds
    • Ground yourself to the motherboard by touching a screw on the chassis
    • Disconnect wire from coin cell battery
    • Touch screwdriver tip lightly against pins the wire connects to for 1 or 2 seconds
    • Reconnect coin cell battery wire
    • Connect AC adapter and power up
    • Press F2 to enter BIOS
    • Set date/time and any of your customized settings
    • Press F10 to save and exit
    • Load Windows
    Note: your system may start beeping after clearing the CMOS. Don't panic. Hold down the power button to shut it off. Turn it on again, and it should restart and clear itself by resetting BIOS defaults. If your OS was installed incorrectly with the BIOS set to AHCI instead of RAID, you may need to manually set that back to AHCI in the BIOS for Windows to load.
    Clear CMOS (Alternate Method):
    • Hold down FN key and power button simultaneously
    • While they are still depressed, re-connect the AC adapter
    5 Beeps after turning ON the Alienware Laptop system
    Article ID: 530513
    Date Published: 2012-03-07
    Journal ID: 9a2a3fd7-0836-4d7b-96ed-b867ba7a4598
    Article Summary:
    This article will guide you to make quick Bios recover by pressing a key combination when turning ON the system.
    [​IMG] Note: Please bookmark this article as restarts of the computer are recommended during the process to help resolve issues.
    Table of Contents:
    1. Applies for:
    2. Problem
    3. Discussion
    4. Solution
    Applies for:
    Alienware M11x R3
    Alienware M14x R1/R2
    Alienware M17x R3/R4
    Alienware M18x R1/R2
    Problem
    Some laptops after turning "ON" makes 5 Beeps and also did not POST.
    [​IMG] Note: POST refers to POWER ON SELF-TEST and is a set of routines that verifies the functionality of each internal component on the computer. If a computer is not posting, one of the issue it may experience is a no video, beeps, computer freezes at the BIOS screen, or any other behavior that didn't allow the computer to start loading the Operating System.
    Discussion
    Several things can affect a system for not to complete a POST. In this case, static electricity or BIOS outdated can cause this behavior.
    Solution
    To fix the issue and have your system working again, please perform the following steps:
    1. Remove the system battery.
    2. Remove the Ac/adapter.
    3. Hold the power button for 30 seconds without any power source.
    4. Plug back the Ac/adapter only.
    5. Hold the “FN” key and without releasing the key, Power "ON" the computer.
    6. After step 5, you will notice the system will try to turn "ON" and after 5 seconds will restart, at this point you can release the “FN” key.
    7. The computer will POST and starts loading Windows.
    8. Shutdown your computer and plug back the system Battery.
    9. Download the latest BIOS version for your Alienware System and run it.
    [​IMG] Note: For How to run a BIOS update, please refer to the following Article: How to run a BIOS update on an Alienware Computer?
    10. Turn OFF your computer after the Bios update and test your computer.
    Thank you for your inquiry,
    The Alienware Support Team
    Quick Tips content is self-published by the Dell Support Professionals who resolve issues daily. In order to achieve a speedy publication, Quick Tips may represent only partial solutions or work-arounds that are still in development or pending further proof of successfully resolving an issue. As such Quick Tips have not been reviewed, validated or approved by Dell and should be used with appropriate caution. Dell shall not be liable for any loss, including but not limited to loss of data, loss of profit or loss of revenue, which customers may incur by following any procedure or advice set out in the Quick Tips.​
