[Req]Procedure for Crisis REcovery diskette [Recovery bios fail]
Discussion in 'Other Manufacturers' started by harsan, Jul 29, 2006.
  1. harsan
    harsan Notebook Geek
    Hi guys
    I have update the bios with winplash, but during update . the windows has crashed.
    Exisist one procedure for recovery bios?
    I have read for a Crisis REcovery diskette procedure.
    Exist a valid procedure for recovery the bios?
    very thanks
    harsan
  2. dreassica
    dreassica Notebook Guru
    I had same thing, crisis disk procedure didnt work here, usb stick, cdr or usb floppy drive with crisis disk+proper fw file, it searches teh device but doesnt do anything. My bet is that u gotta contact dealer and apply for RMA, worked for me.
  3. harsan
    I guys ,
    i have resolved this problem.
  4. harsan
    IMPORTANT Crisis Recovery Diskette----
    Tool for recover your bios fail
    Download this tools
    http://rapidshare.com/files/30431263/268076.exe
    insert one formatted floppy and click Ok.
    Now , in the floppy disk, erase bios.wph ( generic phx bios) and copy your latest bios file ( for compal hel 80) renamed in BIOS.WPH
    Combination of notebook keys
    1, remove the battery, attacked the local power source from net.
    Insert in your usb port the external floppy usb.
    the usb ports are those one of the two that is found near the DVD+-
    2. You hold pressed Fn+B or Win+B
    3, press power on.
    4. On the screen it does not appear null, seems all like before.
    ( all led is off)
    5. The light of the floppy one will be ignited, this is sign that the procedure works.
    6. Left to read the floppy one, us want approximately 2 min in order to end the procedure.
    7. When the light of floppy is off, please wait 5 minutes and power off the notebook (disconnect AC adapter)
    8. power on the notebook ---- ENJOY
  5. dreassica
    Did that actually work for you?/ I tried it in so many ways and it just didn't do anything.
  6. harsan
    yes :)
    work very well
  7. dreassica
    Did u use a usb floppy drive?
  8. harsan
    yes dreassica, i have used a floppy drive usb Mediacom.
  9. dreassica
    Odd it didn't work fo rme then, matbe it's because i just used a crisis recovery disk from other manufacturers, who also had phoenix bios on their laptop, and just replaced their bios with the one for hel80.
  10. harsan
    the necessary is a possible latest bios for hel80
    I have used file rom ver 1.05b.
    rename this bios in bios.wph
    and etc...
    is simply :)
Similar Threads - [Req]Procedure Crisis REcovery
  1. lajoes
    911
