Replacing 2k display by 4k display, is that possible??
Discussion in 'Sager and Clevo' started by grunnsat, Apr 16, 2018.
  1. grunnsat
    grunnsat Notebook Consultant
    If I have a modern Clevo notebook with a 2k display, is it possible to replace it with a 4k display?
    I'm thinking of the new "U" class Coffee Lake mobile CPUs. I hope there will be a Clevo notebook for these CPUs, and without a graphics card. The CPU supports 4k (eDP 1.4), and as I understand this, the 2k displays use the same 40 pin interface as the 4k displays.
  2. Chastity
    Then you should be good to go. Whether it retains GSync capability is another matter.
  3. Maleko48
    Maleko48 Notebook Evangelist
    As long as the pinouts are the same and both screens have equivalent connectors, and you can deal with potential mounting differences, I don't see why not? You will almost certainly lose GSYNC due to whitelists and red tape. I would recommend comparing data sheets to see if the pinouts are the same or similar. If they are not, you could have a custom cable made by that one site.
  4. RampantGorilla
    RampantGorilla Notebook Deity
    The Intel iGPU (Gen 9.5/ gen9) only supports DP 1.3.
  5. Meaker@Sager
    eDP and DP are different standards in version number so check closely.
  6. grunnsat
    Thanks for all your replies.
    G-Sync is of no importance to me, as far as I'm aware. G-Sync seems to be of interest with gaming, I don't do that. Watching a video is about the fastest thing I do on a display.
    According to paragraph 2.2 of the Datasheet for these processors:
    https://www.intel.com/content/dam/w...ocessor-family-s-platform-datasheet-vol-1.pdf
    the IGP supports eDP 1.4.
    Now I only have to wait until Clevo comes up with a new notebook for the i7-8559U
  7. grunnsat
  8. Meaker@Sager
    Due to the expense of such a panel and the focus on other features colour accurate panels are rarer.
  9. grunnsat
    They are not that expensive, € 112 or so. Everybody has a digital camera these days, and use a PC to edit them. It is almost impossible to accurately judge colours on a non calibrated PC screen. I use a X-Rite Display colour calibrator to at least get colours that are not far too blue and too red. The difference between the colours of an non calibrated PC screen and a calibrated one is remarkable.
  10. Meaker@Sager
    Your price and the bulk price of the OEM are usually very different. If you want to do any kind of serious editing then a calibration tool will always be a must.
