Replacement power supply for GL702ZC gives up
Discussion in 'ASUS Gaming Notebook Forum' started by tkalfaoglu, Nov 22, 2018.
  1. tkalfaoglu
    tkalfaoglu Notebook Enthusiast
    Hi there. I recently bought a replacement power supply (noname brand) for my GL702ZC so I would not have to carry it between work and home. Both the laptop and the power supplies for it are monsters -- huge and heavy.
    Anyway, the new adaptor switches off then on often while playing a game.
    I am guessing that it cannot keep up with the demand. I am a hacker at heart, so I was wondering if adding an active cooling to the brick would help. I could take the power supply apart and add cooling.. Any ideas? has anyone done anything crazy like that?
    Thanks, -t
  2. Danishblunt
    Danishblunt Guest
    Honestly just get a proper one instead. it's rather dangerous what you're donig right now, the PSU can blow up your notebook.
    But yes, I had the same issue on my P375SM-A, bad cable on my Power supply caused my system to shutdown on overclock.
  3. Support.2@XOTIC PC
    The ASUS Store should have a 180 or 230W power adapters that fits your model available.
  4. senso
    senso Notebook Evangelist
    There is no space inside a laptop power brick to add anything, its full to the brim with the actual PSU.
