Replacement Laptop Battery Question
Discussion in 'Hardware Components and Aftermarket Upgrades' started by foosa123, Oct 27, 2012.
  1. foosa123
    foosa123 adsfjldsajflkajsdfa
    So after about 5 years, my laptop battery is officially done. Can't hold a charge for more than 30 min or so and now it won't even recharge.
    Using the model number of my battery, I checked out some on ebay that are quite reasonably priced (~$25 + shipping). Both voltages are the same so that shouldn't be a problem. Only difference between my battery and the ones I'm looking at buying is the capacity. Mine says 4800mAh, and the one's I'm looking at on ebay are 5200mAh. I'm just wondering if it is okay to get one with a higher capacity. Will it still work fine?
    The same battery with the exact same capacity as mine on ebay is more than double the price of the 5200mAh batteries, which is pretty ridiculous.
    Thanks
  2. namaiki
    namaiki "basically rocks" Super Moderator
    You're probably looking at the difference between genuine/official and 3rd party parts. Can't say that I've tried purchasing a generic battery, but I suppose that they've got to work at least for a while. Some generic batteries require you to install a BIOS hack.
