replaced my screen now its dim help plz :( , help fix edid
Discussion in '2015+ Alienware 13 / 15 / 17' started by ashknani, Jul 30, 2017.
  1. bloodhawk
    bloodhawk Derailer of threads.
    Check with @Khenglish
  2. Khenglish
    Khenglish Notebook Evangelist
    Sorry, this website does not work well on my phone. I'm trying to get the text in.
  3. ashknani
    ashknani Notebook Consultant
    Could u please hurry up.
  4. bloodhawk
    Whats the rush dude?
    First thing, people are trying to help you out. Second, if this is so inconvenient to you, just switch back to the old panel.
    Either ways im out. Hope you get this sorted.
    Paull likes this.
  5. ashknani
    Coz I have been looking for the solution for three days im so excited to try it o.o ?
  6. Khenglish
    When putting a non-standard display in a laptop with an Nvidia gpu it is often necessary to manually enable brightness control in the Windows registry.
    The location it goes in is
    HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\...
    From the Class folder search for your GPU name, for example "980m", and you should end up in a folder called 0000, 0001, 0002, etc with a bunch of keys like EnableDpLibrary and EnableCoprocPowerControl.
    The DWORD you want to add is the following:
    EnableBrightnessControl
    After creating it set it equal to 1.
    Gotta disable javascript for this website.
    Also telling me to hurry up made me not log in from my work laptop to post this half an hour ago.
    Vasudev, t456 and bloodhawk like this.
  7. ashknani
    Im sorry if u felt offended I didnt mean it that way I was only excited and it didnt work.
  8. Khenglish
    Was the entry already present?
    You need to restart the computer after adding it. After the restart you can use the display brightness sliders in Windows. The default brightness will still be low.
  9. ashknani
    No it wasnt present and yes I restarted and tried to increase or decrease it still wont work :(((((((
  10. ashknani
    When im in the boot menu it works at highest and dianogstics but when alienware logo appears after that in 2 secs there is like some glitch happen to that logo and thats the moment it goes dim I dont know what file load makes it happen like this.
