replaced my screen now its dim help plz :( , help fix edid
Discussion in '2015+ Alienware 13 / 15 / 17' started by ashknani, Jul 30, 2017.
  1. ashknani
    ashknani Notebook Consultant
    hello everyone, today i replaced my QHD TN with an IPS 120hz FHD ( b173han01.1 ) and it works flawlessly without nvidia drivers installed but I when install them, the screen immediately goes dim I cant play or what videos and g-sync is gone too but this screen supports g-sync :((((
  2. Vasudev
    Vasudev Notebook Prophet
    Have you checked the brightness level after swapping out the display?
    Which version of Nvidia driver you used?
  3. ashknani
    Its the latest nvidia driver, I have found out the issue, when i go to device manager on that display events tab it says device is not migrated.
  4. Vasudev
    Have you Windows Update to do auto updates? If so, disconnect from internet and retry the driver in device manager.
    Right ur GPU then click Update Driver, Choose Manually browse for driver and hit next until the driver install progresses.
  5. ashknani
    Dude its the monitor not the GPU.
  6. Vasudev
  7. ashknani
    Will the calibration somehow make it work ? The G-sync is not showin in nvidia while it should , It means I have no control over the screen what so ever so I believe I need to have some sort of driver to make it work calibration will only fix the colors , I saying this because If I want to do this I would have to open my laptop again and disemble the panel and put the other one.
  8. Vasudev
    Did you get GSync cerification symbol on your Display packaging? See this thread AW17 R4 - 4K Screen Design Fault???
  9. ashknani
    Which one is the g-sync certification symbol ?
  10. ashknani
    I Believe I have it , The weird thing is that when im in boot menu I selected Dinaostics option and tested the screen its so bright and it showed the colors in the test but at the moment it loads the system it suddenly goes dark
