Replace Alienware 15 R2 wireless card, possible?
Discussion in '2015+ Alienware 13 / 15 / 17' started by Kontralien, Oct 11, 2018.
  1. Kontralien
    Kontralien Notebook Enthusiast
  2. Muezick
    Muezick Notebook Consultant
    So as for the WiFi Direct feature for a PS4. I have my doubts.
    But you can most certainly replace the WiFi card in your system with the 8265.
    Source: https://downloads.dell.com/manuals/all-products/esuprt_laptop/esuprt_alienware_laptops/alienware-15-r2_service manual_en-us.pdf
    As a side note, one of the main reasons i buy dell products is because they are very good about supplying these manuals and keeping these manuals available for years and years and years after the product has left production.
    Edit: Be very very careful with the wifi cable connectors. I've had the garbage killer wifi connector links break off right into the tip of the antenna cable. I hate killer products because of how cheaply made and how horrible their performance is.
  3. Kontralien
    Thanks for the info. I'm also not sure if the Wifi Direct will work but will update you if it does.
    Vasudev likes this.
