Repasting with CooLaboratory Liquid Ultra, any tips before I start?
Discussion in 'Alienware' started by [Nikos], Jan 3, 2014.
  1. Rimas
    Rimas Notebook Geek
    You guys might now more about this than I do, but I find HWInfo quite useless for fan controls because it only lets me control the CPU fan :(
    Is there something I'm missing? Only the first fan is customizable and if I set it to a manual or custom auto - the GPU fans stop, the CPU fan is the only one that reacts and my GPUs gradually heat up into the oblivion... Any ideas?
  2. Papusan
    HWINFO64 SETTINGS...
    Uncheck EC Support under "Programs -> Settings -> Safety" and THEN be sure to go to the Sensors section and disable monitoring of "DELL EC". Link to a great guide for you. http://imgur.com/a/UYC3s#0
  3. Rimas
    Rimas Notebook Geek
    That worked like a charm! Didn't need the guide, was very straight-forward. Thanks!
  4. Papusan
    You're welcome!!
  5. Mr. Fox
    I wish that would work on Clevo, but it does not. But, they do have other manual fan controls that work well. I just love using HWiNFO64 for everything that I can.
  6. Papusan
    There had been much worse if Clevo as you say does not have Hwinfo fan control had been like Alienware (Offered zero fan control):rolleyes: Hwinfo64 is more than just a fan control. An ingenious software for monitoring of hardware;) Aw 17 and 18 had been ruined laptops without Hwinfo64. Dell should paid developers of Hwinfo64 a big part of its profits:D Maybe 5%:D Do not forget that Dell's engineers and reps recommended Hwinfo because Dell failed to deliver fan profiles that worked the way we wanted.
    Solo wing and Mr. Fox like this.
  7. t456
    Hurray, 9.7 tubes worth of Liquid Ultra:
    Already used the last drop of CLU on an Acer (or something :vboops: ), so this arrived none too soon. Use CLU atm, so:
    1. benchmark run with cpu fan at 100%
    2. check Tmax
    3. repaste with Galinstan
    4. benchmark run with cpu fan at 100%
    5. check Tmax
    The 'fan on full' because otherwise you'd run into fan table differences (steps). Hope to run that test this weekend.
  8. Mr. Fox
    I am looking forward to seeing your test results. The way you purchased that in bulk is clearly the most affordable option for anyone that needs a lot of liquid metal thermal paste.
    Here's this for anyone still having doubts as to whether or not using liquid metal produces better results. I just tested Thermal Grizzly Conductonaut. Results are more or less identical to Coollaboratory Liquid Ultra and Phobya Liquid Metal.
    Bear in mind that the 6700K has been delidded and has Liquid Ultra between the core and IHS. (A 6700K that has not been delidded with liquid metal paste on the die will not achieve results as good as demonstrated here.)
    [parsehtml]<iframe width="853" height="480" src="https://www.youtube.com/embed/4gYL7cjo6qc?rel=0" frameborder="0" allowfullscreen></iframe>[/parsehtml]
    GPU Core Burner Test - GTX 980 (200W MXM) + Prema OC vBIOS
    IC Diamond - 60 second GPU core burner test reached 79°C
    Thermal Grizzly Hydronaut - 60 second GPU core burner test reached 80°C
    Thermal Grizzly Conductonaut - 60 second GPU core burner test reached 73°C
    CPU Core Burner Test - 6700K @ 4.7GHz
    Liquid Ultra - before applying IC Diamond, a 2 minute CPU burn test was run as a baseline for comparison with a result of 84°C
    IC Diamond - 2 minute CPU burn test reached 89°C
    IC Diamond - 4 minute CPU burn test reached 90°C
    Thermal Grizzly Conductonaut - 2 minute CPU burn test reached 83°C
    Thermal Grizzly Conductonaut - 4 minute CPU burn test reached 86°C
    As you can see in the video, a little bit goes a really long way with liquid metal thermal paste.
  9. A-leo
    A-leo Notebook Guru
    hey mr fox
    what is the best paste for my current situation?
    if i can make it to 3.9 ghz after repaste it will be awesome
    thanks again
  10. Mr. Fox
    Coollaboratory Liquid Ultra, Phobya Liquid Metal or Thermal Grizzly Conductonaut are all very similar contents and produce comparable results. As long as your CPU heat sink fits nice on the CPU they should work fine. If the CPU heat sink is a sloppy fit, then you'll need to use IC Diamond to plug the gap, because liquid metal pastes do not work well in that scenario.
    A-leo and hmscott like this.
