Repair M17 R1 or Replacement? Advice required
Discussion in 'Alienware 17 and M17x' started by tinker_xp, Feb 5, 2017.
  1. tinker_xp
    tinker_xp Notebook Consultant
    Hi Guys and Gals,
    I'm after some professional advice if I may.
    My Alienware M17 R1 (see sig) has been playing up massively and now it looks like the battery and GPU may need replacing. Of course the beauty of this laptop that it was the last Alienware to have a MXM board so of course I/Dell can just replace the majority of parts under warranty without the motherboard etc being removed :p
    However, a new laptop is appealing (isn't it?) New 7000 series CPU (BGA filth, I know) but also the 1000 series GPU, new display, Alienware GPA compatible etc. But, the new laptop's are all BGA, don't have a blu-ray drive nor a standard 2.5mm hard drive caddy but my extended warranty expires in September 2017 so if the new laptop fails beyond that then I would find myself up a creek without said paddle - But it shouldn't fail, should it?
    I know some swear by their ye old faithful laptops, and some have ordered new Alienware BGA laptop without a care in the world ¯\_(ツ)_/¯ so thought I would look for some advice from the community.
    Thanks!
  2. Spartan
    Spartan Notebook Nobel Laureate
    Your GPU is like 3 generations behind, your RAM is DDR3 @ 800 MHz? also very slow storage sub system.
    I suggest you upgrade but not to an Alienware 17 R4, instead I suggest getting the MSI GT73 VR Titan Pro.
    It has more RAM slots (4 vs 2 on the Alienware), it has more storage (2x m.2 NVMe PCIe slots + 1 regular m.2 slot + 1 2.5" HDD/SSD slot), it also has a better 120hz / 5 ms GSYNC screen, the colors are better than the one Alienware has as that's QHD but also has horizontal banding line issues
    If you are fine with only 32GB RAM and lesser storage then you can get the new Alienware with Tobbi eye tracking and the graphics amp but do note that cooling on the MSI is superior and their screens don't suffer from the backlight bleeding which has plagued Alienware for years all the way since the Alienware 18
    Check the MSI laptops here:
    http://www.hidevolution.com/catalogsearch/result/?a=all&q=gt73vr
    Alienware here:
    http://www.hidevolution.com/new-laptops/shop-by-manufacturer/alienware/17-laptops
  3. tinker_xp
    Hi Phoenix,
    Firstly thanks for the comprehensive reply! It's appreciated.
    I should have elaborated further when I said 'replacement' as the replacement would be from Dell/Alienware as I know after several repairs they often look to replace the laptop as you said, it's three generations behind so I don't think a refurb will be an option. It's a mighty assumption that they will just replace it of course but it's a fair one.
    So that takes me back to my original question, stick with the old gal and see through further repairs or potentially accept a replacement whilst I'm still in warranty.
  4. Infinaris
    Infinaris Notebook Consultant
    Sorry to sorta hijack the thread but I've an old M17x myself with a semi bad GPU. Works with hybrid disabled but enabling the graphics brings up a blank screen on windows boot. I can see the mouse cursor but nothing else its black. Is it possible to install a GTX675 into this as a replacement GPU? I got 2 spare ones gathering dust from my M18x.
  5. Ashtrix
    Ashtrix ψυχή υπεροχή
