Removing fan from Vaio
Discussion in 'VAIO / Sony' started by VaioOwner, Jan 29, 2017.
  1. VaioOwner
    VaioOwner Newbie
  2. zimbros12
    zimbros12 Notebook Deity
    You need to remove the heat sink..
  3. B4_685
    B4_685 Newbie
    The 4 screws near the purple cpu block need to come off then it should pull free. Disconnect fan wiring carefully from board. You might need some thermal grease to reattach heatsink....also the black square is another chip - probably video card processor
