Remember that shifting problem? its not there :confused:
Discussion in 'Motorized Vehicles' started by aan310, Aug 9, 2009.
  1. aan310
    aan310 Notebook Virtuoso
    im having it checked when i get the actuator changed since you need to be under the car to get to it (its right at the driver rotor area)
  2. K-TRON
    K-TRON Hi, I'm Jimmy Diesel ^_^
    Get an RTO6610 in it. Eaton makes better transmissions than anything Hyundai makes
    You may need a SAE3 adaptor, but a good machinist can make one. If not advanced adaptors or novak can
    Is your transmission manual linkage, or is it shifted by air jets?
    K-TRON
  3. aan310
    lol wut?
    and almost ANY tranny is better than one made by Hyundai xD
  4. allfiredup
    allfiredup Notebook Virtuoso
    That typically applies only to automatic transmissions, not manuals. Many manual trannys only require motor oil as their "fluid".
  5. allfiredup
    The correlation of a certain RPM and the grinding sounds like a problem with the 2nd gear synchronizer/synchromesh. The clutch could also be the problem, or a significant part of it. But the clutches in most modern vehicles are self-adjusting and a significant problem like this would require replacement of the clutch to resolve!
    What year/make/model vehicle do you have?
  6. aan310
    2003 Hyundai Tiburon Base
    And im not surprised if its the synchro, but hoping its not xD
