reinstalling samsung recovery solution III
Discussion in 'Samsung' started by volly, Apr 16, 2009.
  1. volly
    volly Notebook Enthusiast
    hi, I recently reinstalled windows xp on my blue nc10 using the "system recovery media" disc that came in the box, but when I tried reinstalling all the samsung media with the "system software media" disc, the computer wouldn't complete reinstalling the samsung recovery solution III, saying instead that "there is no samsung recovery area in your hard disk drive. setup will be canceled".
    what should I do to solve this, please?
  2. John Ratsey
    Did you reformat the hard disk?
    The Recovery Solution uses a special partition on the disk.
    John
  3. volly
    yeah, I think I deleted that hidden partition. in my defense, I'm pretty computer-illiterate and had only half a clue as to what the hell I was even doing.
    am I screwed? have I destroyed my chances of reinstalling recovery forever? ):
  4. John Ratsey
    You could contact Samsung support and ask if they have a utility to create the recovery partition on an empty HDD.
    John
  5. volly
    okay, I'll try that. thanks!
  6. paulr5
    paulr5 Notebook Enthusiast
    What was the outcome. I am trying to get revcoery solution 2 to work. I installed a bigger HD and am trying a clean install.
  7. paulr5
    (subscribing)
  8. John Ratsey
    Did you clone the old HDD onto the new one? Cloning software (eg Acronis TrueImage) should copy over the hidden stuff (it used to, but i haven't tried cloning a Samsung HDD recently).
    John
  9. Blofeld
    Blofeld Notebook Enthusiast
    I'm planning to do a fresh install of Windows 7 on my Samsung Q320 in a few weeks.
    Is this something I should bear in mind Re: Recovery Solution II?
    When you say Samsung use a hidden partition, is this in addition to any partitions you can see in Windows Explorer?
    If so, when I do my Windows 7 install, should I keep all partitions exactly as they are when asked during the install process?
  10. paulr5
    If you are doing a fresh install, as in wiping the whole HD, then installing it from disc, you will destroy the samsung recovery solution. My Samsung has c drive, d drive and a hidden partition callled RECOVERY. Only Samsung can reinstall it.
    Why are you doing a fresh install btw. If you have a problem, why not do a purchase point install. Using Samsung recovery solution it puts your pc back to the state when it was purchased. You end up with your hidden partition intact and c drive with a clean version of the operating system.
    Any more questions just ask.
