reinstall hp webcam help
Discussion in 'HP' started by times, Feb 2, 2008.
  1. times
    times Notebook Evangelist
    i just was gonna use my webcam and its not turning on. i tried to find the installer in programs but couldnt find it. where will i find it. can i even reinstall it or do i need to install the whole hp quickplay thingy. it was workn this morn.
  2. flipfire
    flipfire Moderately Boss
    Go to your System Properties > Device Manager > Imaging Devices
    Double click on the HP webcam and uninstall it from there. You do not need to reinstall quickplay, thats a totally different program. It is the drivers that you need to reload
    If re-installing the drivers doesnt work. Go here and try using the Acer Crystal Eye Webcam drivers. http://forum.notebookreview.com/showthread.php?t=149463&
    Follow all the directions exactly as stated and it should work
