Reduce fan Speed
Discussion in 'MSI' started by Zorro!, Nov 25, 2021 at 4:17 AM.
  1. Zorro!
    Zorro! Notebook Enthusiast
    Hello Notebook Review friends,
    i just got this laptop :
    MSI - Modern-15-A10RBS-456FR - Noir 15.6"" Full HD - Comet Lake i7-10710U - RAM 32 Go - SSD 1 To - NVIDIA MX350
    and i dont like the fan noise!
    Before i got an Asus with AMD 4700 and i heard nothing...
    The noise is not huge, but i work all the day with my laptop so each details is important.
    There is 2 fan in this laptop and the Fan 2/Gpu make more noise and turn of more often even i almost never use the GPU!
    I use the the software of MSI Silent Option and i put everything on minimum for CPU and GPU
    and i got the GPU fan around 3000 Rpm in and it is like a cycle of turn on/off 30sec,
    what is very annoying...
    Unfortunately is look like the minimum fan speed for both is 2800, i never saw it work like 1000 rpm.
    1 Is it possible to reduce the speed of the fan under 2800 rpm like 1000 rpm?
    2 Or force it to juste use Fan 1?
    ( i put this setting for CPU and all minimum for GPU like this i try use more the Fan 1)
    3. If i can't find a solution maybe i will return the laptop, and go for an AMD 5700U ( 15 tdp) hoping it make less noise, ( make sense?)
    Thank by advance.
    PS : I am not native English speaker, so sorry for my accent;)
    PS2 : Example of the situation when i just writing on this forum and no big use of CPU.
  2. NeXt3R
    NeXt3R Notebook Evangelist
    WTF ?
    you have the opposite setup :D
    20-30-50-60-100-100 - curve "example + auto cooler booster under 90C"
    1200-1800-3000-3600-5500RPM
    slower spin "load sensitivity correction"
    20-20-30-50-100-100
    OEM - example
    20-40-50-60-80-100
    45C 55C 65C 78C 89C 98C -example for trigger
    edit
  3. NeXt3R
    SILENT OPTION - for older devices "official 5-6TH"
    when not works - DRAGON or MSI CENTER
