Redoing Cooling on ATI 5870
Discussion in 'Hardware Components and Aftermarket Upgrades' started by silentnite2608, Mar 26, 2012.
  1. silentnite2608
    silentnite2608 Notebook Evangelist
    What paste is the best?
    What size is the ram chips?
    So that I can get them pads
    Or switch to paste on them?
    Also Can lapping be attempt on laptop heatsinks?
    Thank you for your time.
    And working on the one's in the spec rig below.
  2. Bog
    Bog Losing it...
    - brand comparisons yield little or no differences in heat dissipation
    - not sure what you're talking about here; SDRAM or VRAM?
    - if the heatsink has thermal pads, applying paste will not work b/c of the larger gap between the chip die and HS
  3. tijo
    tijo Sacred Blame
    1 -> Get a good brand paste, MX-4, ICD7 or some of the others people ehre recommend
    2 -> If you mean the VRAM, on the 5870, it's usually 2 rows of 4 memory chips.
    3 -> If the gap is too high, as bog said, paste won't do, but it's safe to assume that either 1mm or 0.5mm pads will fit nicely.
  4. silentnite2608
    Yes I was talking about the Vram.
  5. niffcreature
    niffcreature ex computer dyke
    If your vRAM is overheating... This only happens in rare circumstances like with Qimonda gddr5... You can use thermal paste and copper shims in place of thermal pads.
    The difference is HUGE. Copper really does the job better.
