Recovery Disk for Sony Vaio VPCZ11Z9E
Discussion in 'VAIO / Sony' started by vpcz11z9e, Oct 21, 2018.
  1. vpcz11z9e
    vpcz11z9e Newbie
    I would like to ask if someone has the recovery disk or usb or ISO file for a clean installation/set up of the VPCZ11Z9E model.
    I recently changed the SSD and I lost the partition with the recovery files. Unfortunately I cannot find my own recovery disk ....
    I will appreciate a lot if you could help me.
    Teo
  2. galaxyge
    galaxyge Notebook Consultant
    Building up from scratch even using recovery disk will be a nightmare, a nice current backup would be a much nicer starting point - but not going to blame you.
    My recommendation, if you are a somewhat technical person, do the bios hack and install Windows 10. There are very good instructions here in the forum, it's been working flawlessly for many here for long.
    Otherwise good luck; there should be someone able to help out with the recovery disk.
  3. vpcz11z9e
    vpcz11z9e Newbie
    thank you for the advice!
    my problem is some drivers which are not available at the web .. especially for the one of the graphic cards..
