Recommend external flash drive or SSD for system image(s)?
Discussion in 'Accessories' started by kylera, Aug 25, 2020.
  1. kylera
    kylera Notebook Consultant
    Title. I'd like something to hold onto recovery system images other than the recovery partition.
    Storage: anywhere between 64GB to 512GB
    Price: up to USD150
  2. Aivxtla
    Aivxtla Notebook Evangelist
    Get a 1TB Samsung T5 its $139.99 at Best Buy assuming you are in the US. Maybe cheaper on some other sites if you look around.
    Spartan@HIDevolution and Aroc like this.
  3. Spartan@HIDevolution
    For system images, I use a Patriot Supersonic Rage Elite as shown in this guide:
    For file backup (Documents, Pics, Music, Videos, Software, etc.) I use a 2TB Samsung T5 Portable SSD as shown in this guide:
  4. Tech Junky
    Tech Junky Notebook Consultant
    I actually just did a ton of comparisons on this and the best option for the $ is Sandisk SDCZ880
    I picked up the 256GB version w/ a discount from either Chase ($15) / Amex (40%) for $53.94 shipped w/ tax, w/o discounts ~$65+tax
    For an in between of speed/capacity and portability it's your best bet w/o venturing into the SSD in a pocket realm like the PNY / Samsung T series.
    Real world transfers
    Advertised 256GB Speed 380MB/s 420BM/s
    SanDisk 256GB WR ~285MB/s R ~360MB/s
  5. Aivxtla
    At that price a legit SSD would be better even if a little more expensive, large transfers on the Sandisk are not always that reliable and it has a tendency to overheat and can burn out, not to mention unlike an actual external SSD (The Samsung T7 500 GB can be had at around $75-80), a small USB stick like that SanDisk drive doesn’t have proper wear leveling or as good quality NAND... the T7 maybe $15-20 more but you get 2x the space and it will last far longer through multiple writes.
  6. Tech Junky
    Always two sides to every recommendation.....
    For repeat tasks like imaging... I would rather put the wear on a SDD stick like the SanDisk than a backup drive in an enclosure or pay much more than $50 for the same speeds when transferring data to/from the stick.
    When I'm moving more than just an OS then I'll pull out my nvme enclosure with a more robust pro drive in it for the speed, stability, and durability the drive will provide for more critical data. The SD Pro though is a good middle ground for those that may not need a full blown mini ssd or a spare nvme laying around to put into an enclosure.
    Sure a typical SSD can push 500MB/s in either direction over Sata / USB
    Conversely I found a drive that competes with the T series by PNY (Pro Elite) when looking for something new this month that was enticing @ $123 that will push NVME speeds around 800-900MB/s. I'm thinking they threw a 2240 NVME into a small enclosure vs sata/msata in the T series.
  7. Striker_LTU
    Striker_LTU Newbie
    I personally use 1TB Crucial MX500 that I plug in using a USB 3 to SATA adapter, cheap and works great so far.
