Recommend an external Bluray/DVD drive
Discussion in 'Hardware Components and Aftermarket Upgrades' started by alexhawker, Apr 21, 2019.
  1. alexhawker
    alexhawker Spent Gladiator
    Can anyone recommend a good external drive? If I'm going to get one, I'd like it to at least read Blurays, I don't care if it can write them (though it seems most will).
    Looking on Newegg and Amazon, I find it hard to see anything that stands out based on reviews/brand/etc.
    Does anyone have one that works well that they'd recommend?
    Thanks in advance.
  2. Dr. AMK
    Dr. AMK Living with Hope
  3. jclausius
    jclausius Notebook Virtuoso
    The Panasonic drive in my signature was a decent drive. You could pair that with an external enclosure to build your own- https://www.amazon.com/s?k=external+slot+12.7mm+enclosure&ref=nb_sb_noss
    However, I have to warn you,if you're wanting this for movies, blu-ray on a PC is not what you would expect. There are multiple players that are buggy and crash half the time on different movies. The menus don't work. I thought about purchasing a couple of different players, but the trials were just as bad as the free-ware competitors. I'd recommend anyone considering Blu-Ray on PC just for the sake of movies to tread carefully.
    joluke, Vasudev, alexhawker and 5 others like this.
  4. alexhawker
    Thanks!
    I mainly want/need an external DVD drive for now - I figured it might make sense to buy one that can do blurays too, for future needs. I don't currently want or need to watch any movies with the drive, but may use it with handbrake at some point down the road...
    Should I just go for a cheap DVD drive instead, you think?
  5. kingofswag187
    kingofswag187 Notebook Deity
    Cheapest one off Amazon/eBay
    Starlight5 and jclausius like this.
  6. jclausius
    If you're going to use it for data, there's a lot of storage for blu-Ray. If you go DVD, that would be the most affordable. I guess it really just depends on your needs.
  7. alexhawker
    I ended up getting this one. So far so good.
    jclausius and tilleroftheearth like this.
