REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. ZamirKM
    ZamirKM Notebook Enthusiast
    j95 likes this.
  2. j95
    j95 Notebook Deity
  3. yichi0101
    yichi0101 Newbie
    Thank you for your prompt and clear reply, @j95. I am just curious...can you let us know why the legacy 8454 is the best version?
  4. ZamirKM
    Removed the audio driver using the Revo Uninstaller Pro. During installation, a window with an error [Error code: 0xE000024B] popped up. Running Windows in safe mode via msconfig, did not help, the same error, can help to solve the problem? thank you
  5. j95
    j95 Notebook Deity
    I mean best audio quality, latest HDA drivers (legacy) sound terrible and will break Creative SBX/SBC due to outdated extensions.
    DDU?? Display Driver Uninstaller.
    - Firstly uninstall current Realtek HDA drivers under Programs & Features (Control Panel).
    - You must disable driver signing before installing drivers. Hold down the Shift key while you click the “Restart” option -> Select “Troubleshoot” -> Advanced options -> Startup Settings -> select “Disable driver signature enforcement” option.
    - Copy extracted "Realtek_UAD...Clevo_mod_.exe" to desktop then run as administrator (Temporarily disable AV software)
    - Follow the instructions in the readme to the letter.
    ZamirKM likes this.
  6. ZamirKM
    Hello @j95. The installation of the driver was successful according to the instructions, there was one more problem, I can not install Realtek Audio Console shows the error window Code: 0x803FB005. Could you help in this situation? Thank you.
  7. j95
    j95 Notebook Deity
    Try this link with Edge https://www.microsoft.com/store/productId/9P2B8MCSVPLN
    ZamirKM likes this.
  8. ZamirKM
    Hello. It was possible to download and install Realtek Audio Control, with the help of the program FixWin 10.0.1.0 cleared and restored Micrsoft Store. Thank you for your responsiveness.
    j95 likes this.
  9. j95
    j95 Notebook Deity
    Glad it worked out!
    Now, disable Power management.
    ZamirKM likes this.
  10. ZamirKM
    Thank you for your patience and understanding, thank you so much! Everything works, everything is fine!
    j95 likes this.
