REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. Danishblunt
    Danishblunt Guest
    @andrewff2
    You can read about the problem about the speakers here:
    http://forum.notebookreview.com/thr...stallation-m18xr2.821387/page-2#post-10770724
    The thread tells the story, even replacing the sub and speakers, won't really improve that much because drivers are mostly broken. The modded realtek driver "from J95" are as useless as the stock ones. They do improve on headphones, sadly that's about it, speakers are still absolute garbage.
    If you want better sound, then don't bother downloading J95s crap and go for this instead:
    http://puresoftapps.blogspot.com/2018/04/realtek-apo-driver.html
    It offers way more sound processing options and more customizability on what you want to test and use-
  2. j95
    j95 Notebook Deity
    Realtek HDA Clevo mods.
    - Testing all released drivers with Clevo support, this is important due to Win10 constant changes, for better or worse lol.
    - Pre-patched and signed DLL (Pihto’s patcher).
    - Unlocked DHT, DDL & DTS.
    - Support for Prema's experimental sBIOS MODs (8700K).
    - Custom Installer.
    I only use Equalizer APO's parametric EQ. 720 is for testing purposes, far better than Creative's MB5 but still gimmick...
    Nothing will drastically improve internal speakers, only small changes between released drivers.
    8454 best HDA driver so far.
  3. epguy3
    epguy3 Notebook Evangelist
    an 8504 FF10 Creative version is available, j95.
    might try to mod this new one for Clevo
    j95 likes this.
  4. j95
    j95 Notebook Deity
    Yeah, already tried 8504, but it has issues with SBC 720. Please test 8504 with MB5.
    Realtek_HDA_6.0.1.8504_Clevo.exe
    SHA1: BA1A1D83D778FE838D2C46C7B48F781F387C95E8
  5. epguy3
  6. j95
    j95 Notebook Deity
    Excluding 8454, latest legacy drivers are a mess. This is not the case with UAD versions.
    Realtek UAD 8519 & 8514 for Clevo (Win10 RS3, RS4 & RS5)
    P870DM-G (UAD mod)
    Driver package contains Realtek UAD, Clevo EQ and Creative extensions.
    Just Follow included instructions.
    Stock/WHQL Realtek UAD supported Clevo models:
    Device manager -> Sound, video and game controllers -> “Realtek(R) Audio” properties -> Details -> scroll down “Hardware Ids”
    e.g. UAD/Stock Supported P870TM(G): HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_15580879
    HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_1558950A
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_15587511
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_15587711
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1558087B
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_1558087C
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_15586451
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_155865A5
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_155867A5
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_155865A6
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_155867A6
    HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_15589501
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_15587509
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_15587709
    HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_155895E1
    HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_155895E2
    Otherwise, download modded version for Clevo models not listed above.
    Uninstallation: kill "Creative.UWPRPCService.exe" with task manager then uninstall Realtek Audio under Programs & Features (Control Panel), delete Creative's entry "UWP.service" with Autoruns (as admin).
    Reboot.
    Edit: 8519 update.
    @Prema, @Mr. Fox, @Papusan, @bloodhawk , @jaybee83
  7. ZamirKM
    ZamirKM Notebook Enthusiast
    Hello, what kind of mod is suitable for my computer P670RS-G?
    HDAUDIO \ FUNC_01 & VEN_10EC & DEV_0899 & SUBSYS_15586B02 & REV_1000
  8. yichi0101
    yichi0101 Newbie
    Thank @j95 for your great work which made the Realtek HD audio alive again!
    I have read all the posts here, but I still have the following two questions:
    (1) Why version 8454 is the best legacy driver until now? Is it because the sound quality or compatibility issue?
    (2) Does the modded UAD driver offer the function of DTS interactive(DTSi) or Dolby Digital Live(DDL)? I could not find the option after installing the UAD version of 8519.
    p.s. My laptop is P650HS-G, and the Realtek HD audio hardware ID is:
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_155865A2&REV_1000
    ipodman715 likes this.
  9. epguy3
    hi j95.
    I may have some bad (or disturbing) news.
    It seems that Realtek has decided to include older versions of the mbapo232.dll & mbapo264.dll files in newer FF10 driver versions.
    Beginning with 6.0.1.8491, Realtek included version 1.2.16.131 of the mbapo232.dll & mbapo264.dll files, which broke support for Creative SBX360/SBX720 software and failed to recognize the onboard Realtek audio device, even with the proper license files generated.
    Versions 8480 & 8485 (and earlier like 8454) had version 2.0.0.3 of those mbapo232.dll & mbapo264.dll files, which made the Creative SBX360/SBX720 software work correctly and properly recognize the Realtek audio hardware. For the life of me, I don't know why Realtek did this. I will attempt to contact Realtek and see if they will put the proper versions in newer driver versions.
    You can check the version of the mbapo232.dll & mbapo264.dll files by right-clicking on any of them in Windows Explorer, select Properties and click on Details tab. The Creative SBX360/SBX720 software needs at least version 1.2.65.x of these DLL files for it to work.
  10. j95
    j95 Notebook Deity
    Since your models are not listed (above), you guys must use the modded version instead.
    Just follow the instructions in the readme.
    Nope, we can't patch UAD/UWP. If you want unlocked DTS, DDL etc install Legacy 8454.
    Yep, I know. Still, version 2.0.0.21 UAD has issues too.
    ipodman715 and yichi0101 like this.
