REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. Papusan
    Use https://www.virustotal.com/#/home/upload
    Yeah, if you trust your AV as the Devil read the Bible you cant download anything.
    j95 likes this.
  2. Lightning_-
    Lightning_- Notebook Consultant
    It's Kaspersky
  3. Danishblunt
    Danishblunt Guest
    I havent checked his newer drivers, but if it includes a cracked SBX 720 version then it's a false positive, the crack will trigger any Anti Virus.
    I doubt that J95 would spread viruses so I highly doubt it is a positive.
  4. Lightning_-
    When I get to installing the exe after extraction I get an error: Install Reatek HD Audio Driver Failure!! [Error Code: 0xE000024B] . It happens when the installation bar is almost finished. Ran as admin, and turned off the antivirus.
  5. Danishblunt
    Danishblunt Guest
    Install via device manager instead.
  6. Lightning_-
    Thanks. All good, disabled driver signature enforcement and it worked.
    j95 likes this.
  7. Lightning_-
    Just following the next steps on the team page. Where do I find RltkAPO64.dll to install the certificate? Or is not required if I ran
    Realtek_HDA_6.0.1.8491_Clevo.exe?
  8. epguy3
    epguy3 Notebook Consultant
    Or this 8454 WHQL full creative package that ASRock recently released for some ASRock Fatal1ty Z370 Gaming series boards, which seem to support more OEMs (including ASRock) than just Clevo and Gigabyte.
  9. j95
    j95 Notebook Deity
    No need to install the certificate, the new installer does it all...
    Just check "C:\Windows\System32\RltkAPO64.dll" -> right click -> Digital Signatures -> Details 'OK'.
    Papusan likes this.
  10. Lightning_-
    Got it, thanks for clarifying.
