REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. jaybee83
    jaybee83 Biotech-Doc
    j95 likes this.
  2. j95
    j95 Notebook Deity
  3. epguy3
    epguy3 Notebook Consultant
    v6.0.1.8485 WHQL FF10 w/ Creative integration (unmodded) [download link]
    hi j95 - if you have time, can you make a modded 8485 driver?
  4. j95
    j95 Notebook Deity
    jaybee83, Papusan and FTW_260 like this.
  5. GMLP
    GMLP Notebook Consultant
    @j95. Could you help please? I followed everything in the readme but DTS and Dolby options still didn’t show up in Realtek HD Audio Manager like your screenshot. I have the P775TM but notice the codec is ALC 898 instead of 892 like yours. Running Win 10 1803. Thanks
    PS: Also the jack mapping seemed messed up somehow. I tried hooking up my Z-5500 in 5.1 Analog 6 channel mode but no sound on rear speakers despite jack plugging popup showed correct mapping. Sound test for rear speakers came out of front L R speakers instead :confused:. However when playing music in Foobar using WASAPI event sound came out through 6 channels correctly.
    j95 likes this.
  6. j95
    j95 Notebook Deity
    Did you install the WHQL option? P870xMx is for previous models with Prema mod like P870DM/8700K support.
    You must reboot before copying RltkAPO64.dll' to "C:\Windows\System32"
    Device manager -> Realtek High Definition Audio -> Events -> scroll down and post a screenshot of the latest event "...inf installed".
    If you have SB connect 360 installed you should disable/stop startup processes/services under task manager and services.msc "Audio Position Service" before installing Realtek HDA drivers. Re-enable aforementioned services after rebooting and copying RltkAPO64.dll...or uninstall SBC 360 before installing drivers.
    Check if the cert was properly installed by right-clicking 'RltkAPO64.dll' "...signature is OK"
    Stop Audio service (cmd admin): net stop audiosrv then copy RltkAPO64.dll (RltkAPO_8485) to "C:\Windows\System32" -> reboot.
    ipodman715 and jaybee83 like this.
  7. GMLP
    Hmm no I did not. I saw 2 download links for 2 exe files and thought WHQL is just the original unmodded driver from Realktek. I used this file: Realtek_HDA_6.0.1.8485_Clevo_P870xMx_P7xxxMx.exe
    Will give another go tonight with the WHQL exe and report back. I ddin't use SB Connect 360.
  8. Dennismungai
    Dennismungai Notebook Deity
  9. NIGHTMARE
    NIGHTMARE Notebook Evangelist
    Does it work in P870TM1?
    Sent from my iPhone using Tapatalk Pro
  10. GMLP
    Nope. Still doesn’t work with the WHQL version. Followed every step to the letter. Dll sig installed and copied fine. Device manager event for Audio driver said inf installed as the last event. No DTS or Dolby like your screenshots. They did show up in Windows Sound manager under Digital Output however no sound came out when selecting either of them. I had to switch back to 2 channel 24/96 for optical to work on the Z-5500. At least now the jack mapping worked correctly after a few restarts.
    Guess the TM machines might have to wait. Just FYI I have used these modded audio drivers on the old ZM and they worked flawlessly just like your screenshots. DTS out and everything using Optical with same speakers.
    j95 likes this.
