REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. infex
    infex Notebook Consultant
    thanks for responding. No popups at all. In order to separate them I have to disable the speakers or make "real digital ouput" the default, but once I unplug i have to revert as the speakers don't work. where would I need to disable this craziness via windows? all I did was update drivers. The real audio console is quite limited so, I wasn't able to find anything specific to work with.
  2. anytimer
    anytimer Notebook Virtuoso
    @j95 what is your policy regarding updates? Is it "If it ain't broke, don't fix it"? Just asking, since we haven't seen an update in months.
    I kind of like that approach, btw., I mean - if the update does not provide improved functionality then what's the point.
  3. Dmitry Zyabko
    Dmitry Zyabko Notebook Enthusiast
    Hello everyone, someone can give a detailed guide on installing this mod? on a guide from the top of the page I can’t
  4. anytimer
    The guide works. A couple of tips:
    0. Uninstall the Realtek and SoundBlaster apps from the start menu (this hasn't actually bothered me, but since you're having trouble, might as well do this beforehand).
    1. Disconnect from the internet until this is done, otherwise Windows Update will helpfully install the driver it thinks is best.
    2. DDU has to be run in safe mode, twice - once to uninstall the Creative/ Soundblaster stuff, and then, without exiting DDU, the Realtek stuff.
    3. Disable driver signature enforcement. Disable your antivirus - this can be tricky depending on your antivirus as some of them don't let you do this easily. Exiting the antivirus only closes the GUI window - the actual protection service is still running. Windows Defender is not very troublesome, but you might have to manually disable services for other antivirus apps, maybe even uninstall it and reinstall it after the modded driver is fully installed.
    4. Install the driver. If you don't get a prompt asking you if you want to allow the installation ( you'll be asked 4 times), you're doing something wrong. Don't reboot after the Realtek driver is installed - just wait until the Creative stuff gets installed (you'll see a command prompt window open for a few seconds, then close).
    5. Once the driver is installed, reboot. Reinstall/ enable your antivirus as needed. Turn the internet back on and install the Realtek and SoundBlaster apps.
  5. Dmitry Zyabko
    With driver from Topic starter ?
  6. anytimer
    Yes. Make sure the driver you select matches the Windows release that you are using, as there are several older drivers there as well.
  7. GMLP
    GMLP Notebook Consultant
    Need HELP please. The latest modded Realtek Drivers seems really broken. Internal laptop speakers are no longer disabled and sound plays concurrently with headphones or external speakers plugged in. Really annoying.
  8. ERGLS88
    ERGLS88 Notebook Enthusiast
    Can anyone tell me if this mod work on Cyberpower pcs Tracer III on the TongFang Chassis GJ5CN6E?
  9. LogantheHamster
    LogantheHamster Notebook Enthusiast
    Heyho,
    I have an annoying issue with the Audio Console; it cannot connect to the RPC-Service and thus I cannot use it. Most of the rest works totally fine*.
    Also note that reinstallation of the driver package and the audio console app aren't solving this issue (I tried twice). Nor did this possible solution: https://community.acer.com/en/discussion/584412/realtek-audio-console-cannot-connect-to-rcp-service
    *Sadly I also can't use my microphone correctly. The inbuild mc works fine under windows, just the Accoustic Echo Cancellation causes extreme distortion sounds, but when i try to use it in any programm, app or whatever it doesn't work at all. Also when I plug in any microphone it will get detected, but doesn't work at all either, the only thing I can hear is the static noise. For this problem I've found yet no solution at all. But it is important for me that it works, 'cause I often use Discord and other apps to communicate.
    I would be really thankfull for any actuall help. ;-)
    Cheers,
    Logan
    P.S.: I am using a Clevo P771zm-G, also known as the XMG u705 by Schenker. It has the best possible hardware built inside, meaning a i7 4790k, 32GB DDR3 RAM, 980M 8GB, G-Sync panel, etc.
  10. bpvarsity
    bpvarsity Notebook Enthusiast
    Sorry I'm new to this but I have a pair of gt72 speakers with subwoofer I'm putting in my laptop. What driver/j95 mod driver does everyone recommend? Thanks!
