REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. Curator
    Curator Newbie
    Hi, is this mod compatible with the P650RS-G? The model I have has the i7-6700HQ and the GTX 1070.
  2. j95
    j95 Notebook Deity
    Yes, just follow instructions...
  3. j95
    j95 Notebook Deity
    Realtek UAD 8612 WHQL
    Realtek Audio Console 1.2.165.0 UWP
    Creative UAD extensions
    Sound Blaster Connect 720° 2.2.3.0 UWP
    SHA1: 5AF9B249C5A486BE85FC857FA5F9AEA52F3DA249
    - Uninstall Realtek UAD/HDA drivers, SBC (UWP) and Realtek Audio Console (UWP), including Autoruns step "“UWP.service” (Creative) and "Realtek" audio entries
    (careful not to delete Realtek card reader entry) then reboot.
    - Disable driver signature enforcement. Hold down the Shift key while you click the “Restart” option -> Select “Troubleshoot” -> Advanced options -> Startup Settings -> select “Disable driver signature enforcement” option.
    - Temporarily disable AV software.
    - Copy to desktop then Right-click/Run as administrator “Realtek…mod.exe”.
    - When prompted (4x) select “Install driver software anyway” (UAD).
    - Realtek installer, select “No, I will restart my computer later” to continue with RTK Audio Console & SBC installation.
    - Finally, reboot.
    - Realtek Audio Console -> disable "Power Management".
  4. anytimer
    anytimer Notebook Virtuoso
    I've heard that Realtek had developed a dll that provided native ASIO support. Anyone know more about the current status of that?
  5. j95
    j95 Notebook Deity
    Realtek UAD 8619 WHQL
    Realtek Audio Console 1.2.167.0 UWP
    SHA1: 85DA50A9919D80E3318A748AC89BAF4EF4856288
    - Finally, reboot.
    cj_miranda23, Kelvin2k5 and infex like this.
  6. HitZ2976
    HitZ2976 Notebook Enthusiast
    It seems that i can't use mono microphone with your drivers, since I only got the option for 2 channel in the default format. When i plug it, i sound atrocious and i think that is the culprit.
    infex likes this.
  7. infex
    infex Notebook Consultant
    That might be my issue as well as on discord everyone has been complaining with my voice or the sound.
    HitZ2976 likes this.
  8. HitZ2976
    Well i'm by no means competent, but its logical that there would be problem when using a single channel (mono) mic with drivers forcing 2 channels (stereo). I'm not sure though if realtek designed it that way or its just this driver released by j95.
  9. j95
    j95 Notebook Deity
    Set ext. MIC as default device and disable MIC enhancements under SBC and RTK Audio console.
  10. optimisez
    optimisez Notebook Consultant
    Hi @j95,
    1) I successfully installed your Realtek UAD 8619 mod on my Clevo P650RS-G but I don't understand why the installer must put at desktop in order to get it install properly.
    2) My laptop has ESS SABRE HiFi, at the time of writing if I install Realtek HD Audio Driver 8642_FF00 Generic or 8642_FF10 with Creative instead of Realtek HD Audio Driver provided by Clevo, does it means it will never use ESS SABRE HiFi?
    3) Look like I missing 1 item. Will it affects anything?
    j95 likes this.
