REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. alanfox2000
    alanfox2000 Newbie
    If is have problem from Realtek MOD by @j95, the mod below should work for you.
    ||xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx||
    vxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxv
    Realtek UAD SBC Clevo MOD by alanfox2000 [6.0.1.8581]
    8581_UAD_SBC_MOD_Clevo_Unsigned_04122018
    *For Clevo Laptop which not supported SBC UWP Only.
    j95 likes this.
  2. j95
    j95 Notebook Deity
    I truly appreciate your work but you're wrong here.
    Why did you include Creative.UWPRPCService v1.0.0.10 (2.0.0.14) when you know it's broken? High cpu usage etc.
    With Creative extensions v2.0.0.14 you can't go past v2.2.1.0 (2.1.4.0) SBC/UWP.
    Yes, all INFs were correctly modified.
    Thanks for Vikram's sideloading script though.
    Your mod below.
    P870DM-G (SBC not supported) my 8581 mod...people following instructions correctly.
  3. andrewff2
    andrewff2 Notebook Evangelist
    Hi there j95, i got an P151EM, tried some modded drivers but none are working can u point me wich version should i use in your site (https://premamod.wordpress.com/2017/08/15/j95-realtek/)
    Thanks for the help by the way
    Edit:
    Ok it only worked with an old driver version but SBC 720º still not working
    Used this versions:
    Realtek_HDA_6.0.1.8491_Clevo
    Sound_Blaster_Connect_2_720°_ 3.2.28.0
    j95 likes this.
  4. alanfox2000
    alanfox2000 Newbie
    This is Generic UAD Mod which also work on Clevo Laptop
    Realtek UAD SBC MOD [6.0.1.8564-05122018rev2-Unsigned] (Link)
    j95 likes this.
  5. j95
    j95 Notebook Deity
    To switch back to legacy HDA drivers, you must first fully uninstall Realtek and Creative UAD, SBC/UWP and Realtek Audio console.
    Uninstall Realtek UAD drivers, SBC (UWP) and Realtek Audio Console (UWP), including Autoruns step "“UWP.service” (Creative) and "Realtek" audio entries (careful not to delete Realtek card reader entry) then reboot.
    Disable driver signature enforcement. Hold down the Shift key while you click the “Restart” option -> Select “Troubleshoot” -> Advanced options -> Startup Settings -> select “Disable driver signature enforcement” option.
    Temporarily disable AV software.
    Copy to desktop then Right-click/Run as administrator “Realtek_HDA_8569…mod.exe”.
    When prompted (2x) select “Install driver software anyway”
    Realtek installer, select “No, I will restart my computer later” to continue with SBC & connect service installation.
    Finally, reboot.
    EDIT: P151EM
    HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_15585106?
    @andrewff2 don't install yet, I'll update all HWIDs.
    @alanfox2000 Creative.UWPRPCService v2.0.2.4 solves SBC 2.2.3.0 compatibility issues.
    8581
    Papusan likes this.
  6. andrewff2
    Hey @j95 even with your driver “Realtek_HDA_8569…mod.exe”. it did not work (used revo uninstaller to remove everything)
  7. j95
    j95 Notebook Deity
    Papusan likes this.
  8. andrewff2
    Lol man sorry, tired from work and too lazy too read it right :/
    Papusan and j95 like this.
  9. j95
    j95 Notebook Deity
    219 Clevo supported models, both UAD and HDA legacy.
    Realtek UAD 8581 WHQL
    Realtek Audio Console 1.2.156.0 UWP
    Creative UAD extensions
    Sound Blaster Connect 720° v2.2.3.0 (UWP)
    SHA1: 6A235A1C5CE70F7DFB8C243AAD582F94C9CD034B
    Realtek HDA 8581 WHQL (Legacy)
    Sound Blaster Connect 720° v3.2.28.0
    SHA1: E60CB6DC024E3937AAECEB052F9D3B7424DE7556
    - Uninstall Realtek UAD/HDA drivers, SBC (UWP) and Realtek Audio Console (UWP), including Autoruns step "“UWP.service” (Creative) and "Realtek" audio entries (careful not to delete Realtek card reader entry) then reboot.
    - Disable driver signature enforcement. Hold down the Shift key while you click the “Restart” option -> Select “Troubleshoot” -> Advanced options -> Startup Settings -> select “Disable driver signature enforcement” option.
    - Temporarily disable AV software.
    - Copy to desktop then Right-click/Run as administrator “Realtek…mod.exe”.
    - When prompted (4x) select “Install driver software anyway” (UAD).
    - Realtek installer, select “No, I will restart my computer later” to continue with RTK Audio Console & SBC installation.
    - Finally, reboot.
    Papusan likes this.
  10. andrewff2
    Thanks @j95 by the way whats the best between UWP and SBC
    Edit: Omg i'll sleep 2am and im tripping hard not the best (one link is for legacy UAD and the other HDA) but i should use legacy right?!
    Edit 2: Tried UAD did not work will try HDA now (Uninstalled everything using revo and reboot)
    Edit 3: HDA did not work as well... Am i doing something wrong??
