REALTEK HD AUDIO MOD For Clevo
Discussion in 'Sager and Clevo' started by j95, Mar 23, 2018.
  1. j95
    j95 Notebook Deity
    Did you upgrade windows recently? Windows won't reinstall modded drivers during the upgrade process.
    It's fine, I meant a simple mistake. Secure boot enabled or anti-virus *HIPS* messing things up during installation.
  2. alanfox2000
    alanfox2000 Newbie
    I have check the inf files inside Realtek_UAD_6.0.1.8569_Creative_SBC_UWP_Clevo_Mod.exe. The inf files have not been modified.
    If you want SBC UWP using on your non-official support SBC UWP Clevo laptop, you need a realtek mod driver with inf modified or APO Driver
    If you install Realtek mod driver with inf modified, you need to disable driver signature enforcement
    Realtek UAD for Clevo 6.0.1.8578 WHQL (Official Driver)
    https://github.com/alanfox2000/real...es/download/6.0.1.8578/8578_UAD_WHQL_Clevo.7z
    Creative - Thirty Party Extension
    https://minhaskamal.github.io/DownG...-audio-driver/tree/master/ThirdParty/Creative
    Step
    1. Install Realtek UAD for Clevo 6.0.1.8578 WHQL through setup.exe
    2. Install Creative - Thirty Party Extension
    - Find Realtek Audio on Device Manager
    - Click Update Driver, enter path of the folder where CreativeExtension.inf stored in this dialog > Click Next
    If you don't get install success message, this mean your clevo laptop not official support SBC UWP
    If you install successfully, keep following the step 3
    3. Under software component, you can find "Sound Blaster Connect" and "Creative Audio Effects Component" if you laptop support SBC UWP
    4. Double click two of them and update driver, enter the path of the folder where CreativeComponent.inf and CreativeSBConnect.inf.
    5. SBC UWP will download and install automatically from M$ store if inf install successfully.
    j95 likes this.
  3. j95
    j95 Notebook Deity
    @alanfox2000 Yes, both Realtek (UAD) and Creative INFs have been modified. Creative vendor Id "1102" is supported by most Clevo laptops, therefore I only need to modify CreativeExtension.inf to add SBC/UWP support...with windows 10, RTK UAD is superior to legacy HDA drivers and many Clevo EOL models lack official UAD support.
    Anyway, SBC/UWP is connected but not rendering (2.0.0.14). It seems that latest Creative APOs (UAD) HWIDs are hard-coded.
    Thanks for 8578.
    Realtek UAD 8578 WHQL
  4. Lightning_-
    Lightning_- Notebook Consultant
    I did another critical update today and the same thing happened - Windows seems to reinstall the original unmodded driver over the modded one during the update process. Event Viewer for the device shows this. I just uninstalled it and reinstalled the modded one and it works fine though.
    j95 likes this.
  5. j95
    j95 Notebook Deity
  6. liosafe
    liosafe Notebook Enthusiast
    Hello I need some help. I install your mod Driver 6.0.1.8581. on a Clevo P870DM3
    when I tried to call
    it's working
    It's said your audio device can't be detected
    Thank you
  7. j95
    j95 Notebook Deity
    RUN -> type: services.msc
    Check for "UWPService" then restart service -> run SBC.
  8. liosafe
    I did like you said but it's not working
    and it's only ask me 3 times not 5:
    When prompted (5x) select “Install driver software anyway”
    +when it's said reboot system i choose no. and after 2 more windows that pop and nothing after
  9. alanfox2000
    alanfox2000 Newbie
    SBC don't work correctly if you don't modify HDX_ClevoExt_RTK.inf
    j95 likes this.
  10. j95
    j95 Notebook Deity
    Edited post, it was working fine...I'm dropping SBC/UWP support for the time being.
    If you want SBC then install legacy HDA drivers below.
    As I said before, all required INFs were modified accordingly.
    HDXClevo.inf
